You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.4 (535) English
#1 PSPad unicode 5.0.4 (535) English
Posted by: pspad | Date: 2020-11-21 12:27 | IP: IP Logged
Download links (5.7 MB):
SHA1 hash:
SHA1 hash:
7e41f492742d2d5363dfaeed70a54d98ea910c9c pspad504b535.zip
9a2ba9264e4e50b10d35d97a7b926248c3d2615f pspad504b535x64.zip
Changes to 5.0.4 (531)
News:
Code explorer - search is case insesitive, Alt, Ctrl, Shift doesn't reset search, Ctrl+Enter search for next occurence
Sort lines uses "stable sort", If lines are same, order isn't changed. It has meaning for sort by column.
FTP quick search box is case insensitive
FTP - new field for change folder with history for each server stored in Recent.ini. ENTER confirm entry and send command to FTP server.
New user highlighter definition for Solidity
Open files panel - possibility to arrange selected windows Horizontally/Vertically
Python highlighter - problem with triple quoted strings and escape char
Non maximized windows inside editor was maximized after restore
C++ Code explorer detect printf in some cases as function
#2 Re: PSPad unicode 5.0.4 (535) English
Posted by: MadCompie | Date: 2020-11-30 11:28 | IP: IP Logged
Love the FTP case insensitive search!
