You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.4 (531) English
#1 PSPad unicode 5.0.4 (531) English
Posted by: pspad | Date: 2020-10-13 10:56 | IP: IP Logged
Download links (5.7 MB):
SHA1 hash: SHA1 hash: 03bf52b2777486c3ddcb05e0fa8dc6e55d09aa95 pspad504b531.zip 48fe054f6e55dfcef3d77990d775b906688ab6a9 pspad504b531x64.zip
Changes to 5.0.4 (527)
News:
Open file list (left tool panel) - possibility select and close more files at once (right mouse)
File info shows current open file last write time
Scripts files are sorted alphabetically before adding to scripting engine. Put underscore to the file name begin if you want to compile e.g. your script library as the first
Sort lines uses "stable sort", If lines are same, order isn't changed. It has meaning for sort by column.
Close all was disabled when no file was open but project was
Code explorer was closed on ESC in some cases
Add accent marks (menu Edit / Special conversion)
Highlighter settings / Right edge position - there was possible to set 2 digits number only for the right edge position
Autocompletion window with styles - window title
#2 Re: PSPad unicode 5.0.4 (531) English
Posted by: Bobf | Date: 2020-10-16 13:13 | IP: IP Logged
Hello Jan,
the new build 531 will not found running PSpasd "check for updates".
527 is still shown as lastest Dev build.
rgs Bob
#3 Re: PSPad unicode 5.0.4 (531) English
Posted by: pspad | Date: 2020-10-16 13:53 | IP: IP Logged
Thank you. I forgot update build on the web. Fixed.
#4 Re: PSPad unicode 5.0.4 (531) English
Posted by: Professor Bernd | Date: 2020-10-18 06:44 | IP: IP Logged
News:
Thanks for this feature! It works great and helps me a lot!
#5 Re: PSPad unicode 5.0.4 (531) English
Posted by: MadCompie | Date: 2020-10-19 15:38 | IP: IP Logged
Nice job!
My "maximized" problem is also solved by this.
Also love the feature to close "all to left", "all to right" and "all other".
Thumb up!winking smiley
#6 Re: PSPad unicode 5.0.4 (531) English
Posted by: Gabriel_ACE | Date: 2020-10-23 00:52 | IP: IP Logged
hi! new translate to spanish!
forum.pspad.com
Best regards
