You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.4 (527) English
Goto Page: 1 2 Next
#1 PSPad unicode 5.0.4 (527) English
Posted by: pspad | Date: 2020-09-10 12:16 | IP: IP Logged
Download links (5.7 MB):
SHA1 hash:
e9f66844d4afa48e42784cc0792cd645bb7ca355 pspad504b527.zip
1c8a570b96d5b59e538fd81b37cd361eb73095f3 pspad504b527x64.zip
Changes to 5.0.4 (521)
News:
Program settings / Backup - new options allow switch on/off autosave files with computer suspend
Program settings - added search option possibility. Repeated Enter key press search for occurences
Synchronize movement activation is possible even in one splitted window
Project - speed up big project file loading
User highlighter - added support for Ruby symbols
FTP ciphering - updated OpenSSL libraries
handled exception saving PSpad.INI where there were no user rights
handled exception reading internet proxy settings when user has no right to read it.
TextDiff - line change window wasn't moved by second window horizontal scrollbar
Maximized child window when file is open in empty PSPad
#2 Re: PSPad unicode 5.0.4 (527) English
Posted by: gwinkless | Date: 2020-09-10 16:07 | IP: IP Logged
News:
Thanks so much for this, brilliant work smiling smiley
#3 Re: PSPad unicode 5.0.4 (527) English
Posted by: MadCompie | Date: 2020-09-14 06:37 | IP: IP Logged
Hello PSPad!
The maximized problem is still there I guess?
When no file is open: open a file, the file is not maximized anymore.
Then maximize the opened file. All subsequent files will nowopen maximized (= OK).
But after closing them all, any new file will be opened not as maximized again...
#4 Re: PSPad unicode 5.0.4 (527) English
Posted by: pspad | Date: 2020-09-14 07:16 | IP: IP Logged
Can you tell me the way you open new file?
I was forced to remove maximize from global settings, cause it makes flickering and now I need to catch all individual ways.
#5 Re: PSPad unicode 5.0.4 (527) English
Posted by: MadCompie | Date: 2020-09-14 09:51 | IP: IP Logged
1) open PSPad
2) no files are opened
3) in the explorer panel I mostly select a file using FTP ; but the problem is also when selecting a file from the local disk
4) double-click the file... the file contents are in a window ; not maximized
Edited 1 time(s). Last edit at 2020-09-14 09:52 by MadCompie.
#6 Re: PSPad unicode 5.0.4 (527) English
Posted by: pspad | Date: 2020-09-14 09:55 | IP: IP Logged
Thank you, this is exactly what I need to know - open from file explorer or FTP.
#7 Re: PSPad unicode 5.0.4 (527) English
Posted by: MadCompie | Date: 2020-09-16 06:50 | IP: IP Logged
Hi, this last version (527) has been blocked by my anti-virus as "Mal/Generic-S" (from Sophos)... the previous version (521) is ok...
Perhaps something wrong in the binaries?
#8 Re: PSPad unicode 5.0.4 (527) English
Posted by: pspad | Date: 2020-09-16 07:46 | IP: IP Logged
False positive. Send report to Sophos. There is no change, what should cause this problem, EXE is digitally signed.
I guess with next Sophos definition update will be PSPad OK.
#9 Re: PSPad unicode 5.0.4 (527) English
Posted by: MadCompie | Date: 2020-09-16 10:19 | IP: IP Logged
Okay, thx!
#10 Re: PSPad unicode 5.0.4 (527) English
Posted by: Extranjero | Date: 2020-09-19 09:25 | IP: IP Logged
Search in files - some files are omitted
The problem isn't new, occurred in prior versions, also in 'stable' versions:
When searching in files, some files are omitted and don't appear in search results.
Even renaming, duplicating the affected files doesn't change this behavior.
After some investigating I found out that the character combination '&times' (dec 215) followed immediately, without any space by '&not' (dec 172) causes this - doesn't matter if remarked the line or not.
Because in 'real live' phrases this character combination unlikely occurs, I use it (validating phrase before) as separator ...
Goto Page: 1 2 Next
