You are here: PSPad forum > Developer forum - new builds > Bug: Highlighter UNIX Shell Script
Posted by: Greg | Date: 2020-07-10 16:49 | IP: IP Logged
I just sent you an email with screens and files from the 395 beta version i used before putting 511's files ;)
Posted by: pspad | Date: 2020-07-10 17:23 | IP: IP Logged
I must ask you again. Did you load dark color scheme, like PSPad dark in the program settings / Colors?
If you create your own scheme, you need to set basic text/background color in the Program settings / Colors - light font and dark background.
Posted by: Greg | Date: 2020-07-10 20:23 | IP: IP Logged
I did all you asked me, but all i obtained was grey on white. So ok it had the advantage to be visible, instead of white on white, but barely, so i changed directly in the PSPad.ini
Perhaps it's me...
You have all to reproduce the bug... Just put 511's files onto those i sent you and change to PSPad dark Color Scheme... It should put grey on white for results of Search/Replace in files :\
Posted by: pspad | Date: 2020-07-13 10:19 | IP: IP Logged
I found problem with specific configuration.
I hope it's fixed. Wait for the next build please
Posted by: Andreas | Date: 2020-07-17 10:29 | IP: IP Logged
A line does not show the comment color if a $ follows after a #.
#$ I'm a comment line with the wrong color
Posted by: pspad | Date: 2020-07-17 11:14 | IP: IP Logged
I will fix it
Posted by: pspad | Date: 2020-07-17 11:50 | IP: IP Logged
Andreas:A line does not show the comment color if a $ follows after a #.
I hope next build will be OK
Posted by: Andreas | Date: 2020-07-18 18:46 | IP: IP Logged
Thank you very much. I will test it
Posted by: Greg | Date: 2020-07-22 22:41 | IP: IP Logged
Thank YOU :D ^^
I'll wait ;)
Posted by: Sophiekardoune | Date: 2020-07-27 11:24 | IP: IP Logged
Thanks a lot !
