You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.4 (507) English
Posted by: pspad | Date: 2020-06-13 19:26 | IP: IP Logged
Download links (5.4 MB):
SHA1 hash:
1a2ff8e1131967eecf595e69d3441a3be450f47f pspad504b507.zip
4204c46be8e7140462bebf4d086e847ffe7a3d62 pspad504b507x64.zip
Changes to 5.0.4 (505)
News:
INI highlighter - hexadecimal numbers are highlighted
C# highlighter is supported now as basic highlighter instead of user highlighter
Toolbar buttons height with user defined scale in Windows display settings
CSS highlighter - added missing ALL property
Fixed change of the active documents when you minimize/restore maximized PSPad window
Close to SysTray - switching documents after restore
Swap line above/bellow with active WordWrap mode
Posted by: tmpad | Date: 2020-06-15 15:49 | IP: IP Logged
The version ignored my PSPad.INI and created a new one, i.e. I would have lost all my settings.
I had to secure and rename the previous version to PSPad.INI to restore my settings.
Posted by: pspad | Date: 2020-06-15 16:18 | IP: IP Logged
PSPad creates pspad.ini.bak so you have your settings automatically backed up anytime you cjange settings
I found a problem. PSpad should write into [config] section variable
FirstRun=1
This occured when PSPad is started first time. In you are second user who reports it to me. When First run occurs, PSpad loads PSPad light color scheme.
You can use BAK file, add FirstRun=1 into config.
I guess PSpad doesn't "clear" your file, the only problem is PSpad loads default highlighter scheme
Edited 1 time(s). Last edit at 2020-06-15 16:36 by pspad.
Posted by: MadCompie | Date: 2020-06-16 10:47 | IP: IP Logged
thx for looking min/max problem, it works fine now!
indeed I also encountered the loss of highlighting in the ini file
recovered it from a previous version
also an exception message + terminate after installing
i had to delete the cache file and now everything works fine ; perhaps the cache file should be deleted after every new version install? (in my case i "install" it just by copying the zip contents...)
Edited 1 time(s). Last edit at 2020-06-16 10:47 by MadCompie.
Posted by: pspad | Date: 2020-06-16 10:52 | IP: IP Logged
PSPad cache file is compatible inside 5 version. When PSPad detects it's corruption, PSPad deletes it.
