You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.4 (505) English
Posted by: pspad | Date: 2020-06-07 16:11 | IP: IP Logged
Download links (5.4 MB):
SHA1 hash:
fef8e18bf28965742c9d633ecd1cca42e240e256 pspad504b505.zip
b7a5005fe8ab1f8a537333fa13d833a20517b238 pspad504b505x64.zip
Changes to 5.0.4 (502)
News:
Color schemes are stored per user highlighter slot instead of previous system where all user highlighter slots has common scheme.
File explorer - remembering size and resizing file box
Toolbar buttons height with user defined scale in Windows display settings
Posted by: mikeho | Date: 2020-06-08 18:15 | IP: IP Logged
64 bit About dialog shows it as 5.0.4 (504)
Posted by: pspad | Date: 2020-06-08 18:32 | IP: IP Logged
I know. It's typo only, the compilation time is correct.
Posted by: Bobf | Date: 2020-06-09 11:15 | IP: IP Logged
Hello Jan,
it seems PSpad 5.0.4 (32bit) still has problems with tab restore and systray.
env Windows 10 Enterprise 64bit PSpad 5.0.4 (32bit).
- open pspad and open e.g 4 tabs.
- write into all 4 tabs.. something
- assume the setting is enabled (press X, minimise to Systray )
- click on X, PSpad will minimised to Systray
- click on the PSpad icon in the Systray to restore it.
- PSpad comes back, but only one tab is open, the rest is closed.
rgs Bob
Posted by: MadCompie | Date: 2020-06-10 06:35 | IP: IP Logged
Hi Jan,
Indeed there's something wrong I guess with the tabs. With the former version I mentioned the behaviour of open files + minimize + restore.
The problem still occurs :
- open pspad
- open recent file 1: the focus is on file 1 and the tab becomes bold
- open recent file 2: the focus is on file 2 and the tab becomes bold
- minimize pspad
- restore pspad
- the focus is on file 1 ?
Other simulation:
- open pspad
- open recent file 3: the focus is on file 3 and the tab becomes bold
- minimize pspad
- restore pspad
- the focus is on file 2 ?
Perhaps there is an index problem for restoring the tabs : (index - 1) instead of index?
Posted by: pspad | Date: 2020-06-10 06:50 | IP: IP Logged
I tried it many times, but I wasn't sucessfull to simulate it.
Can you send me your PSPad.INI? Maybe it depends of some settings.
Posted by: MadCompie | Date: 2020-06-10 12:43 | IP: IP Logged
ok, I sent you a PM
Posted by: pspad | Date: 2020-06-10 13:27 | IP: IP Logged
OK. With your config I am able to simulate it.
I am really currious, what can cause such stupid behavior
Posted by: pspad | Date: 2020-06-10 13:52 | IP: IP Logged
First problem - wrong content of the window was joined with maximixed PSpad. It's fixed.
Now I need to find second problem - PSPad minimized to try. For me the Ctrl+Tab stopped work.
Posted by: Bobf | Date: 2020-06-10 13:53 | IP: IP Logged
Jan, the same with my pspad.ini, i sent?
you are able to recreate it?
Bob
