You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.4 (502) English
Posted by: pspad | Date: 2020-05-31 12:53 | IP: IP Logged
Download links (5.4 MB):
SHA1 hash:
cdbcfb8973b585559f7c4f9970ecfde8e94323e2 pspad504b502.zip
7e8e9847ad0357d98cc6aa8d30a555ae20204861 pspad504b502x64.zip
Changes to 5.0.4 (407)
News:
PSPad saves all files in restart/shutdown state include never saved new files.
Tollbar size change for another than default iconset
FTP - sort by date time
New file, Change syntax dialog and TXT button - file extension was changed to New.*
Close bigger count of files at once caused exception
Many fixes related to skins
Posted by: Gabriel_ACE | Date: 2020-05-31 22:14 | IP: IP Logged
hello, thanks for the new version
but I am having a problem, the Pspad freezes, all the time when I save a file of type * .json
when that happens i must use the task manager to close the pspad forcibly and when reopening it the changes in the file were saved correctly
pspad is not crashing so I can't offer you a screenshot of the error
This is the file
Posted by: pspad | Date: 2020-06-01 05:29 | IP: IP Logged
I tried to simulate it, but I wasn't sucessfull.
Do you use Code explorer or another tools in PSPad?
Is your file open form local drive or some network drive?
What highlighter do you use?
Posted by: Gabriel_ACE | Date: 2020-06-01 20:10 | IP: IP Logged
Hello again, I already found out why the Pspad was wrong
The reason is that year after year I updated the pspad and over time garbage files were generated.
This caused an internal conflict with the program.
So the quick solution was to do a clean installation, losing all the settings it generated in many years of use.
Today the pspad works correctly with the latest beta version
Anyway I have a backup with the pspad version that is in a bad state
If you are interested in reviewing the conflict, I can upload the pspad to the internet.
but if you really do not consider it necessary, no problem, I will reconfigure my 8 years of modifications on the pspad
Posted by: pspad | Date: 2020-06-02 03:12 | IP: IP Logged
You can test bad state with deleting pscache.bin file
Posted by: Gabriel_ACE | Date: 2020-06-02 19:36 | IP: IP Logged
pspad:You can test bad state with deleting pscache.bin file
I do that, and now?
Posted by: pspad | Date: 2020-06-02 19:47 | IP: IP Logged
Does your problem continue when you delete pscache5.bin file?
Posted by: Gabriel_ACE | Date: 2020-06-02 20:50 | IP: IP Logged
pspad:Does your problem continue when you delete pscache5.bin file?
Yes
Posted by: Gabriel_ACE | Date: 2020-06-02 22:15 | IP: IP Logged
check it if you want
Posted by: MadCompie | Date: 2020-06-05 14:42 | IP: IP Logged
thx for the modifications!
FTP timestamp = perfect
selection of other matches = perfect
yet another issue I encountered:
- open 5 files (in my case it was via FTP)
- set the focus to the contents of the last file
- minimize PSPad
- restore PSPad
- the focus is still on the last file (tab is bold) but the contents are those from another file
