You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.4 (403) English
#1 PSPad unicode 5.0.4 (403) English
Posted by: pspad | Date: 2020-05-20 16:40 | IP: IP Logged
Download links (5.4 MB):
SHA1 hash:
c1b046166da2a997c400ccebd84f3df0a90f7906 pspad504b403.zip
bcb1d6456c4db6ffe18295aff8d700572c2ba132 pspad504b403x64.zip
Changes to 5.0.4 (400)
News:
Internal HTML preview - obsolete Mozilla, based on unsupported Mozilla activeX control was replaced for Chromium based Edge. To test it is necessary to install chromium based Edge Canary build. It can coexists with existing Windows 10 edge without problems.
Editor window - highlight all occurences of selected text. You can switch it off in the Program settings / Editor 2
Search/replace - fix when replace string contains \n (new line)
Scripting - if script runs when PSPad closes, message with script error appeared
Fixed prolems with TXT files and save As dialog filter
#2 Re: PSPad unicode 5.0.4 (403) English
Posted by: Professor Bernd | Date: 2020-05-21 17:41 | IP: IP Logged
Hello. Unfortunately the error message is still there. Here is an example code that is more realistic. (No loop in "Init".)
' TestLoop.vbs
const module_name = "TestLoop" 'this name must be unique !!!
const module_ver = "0.001" 'version
sub MyTestLoop()
Dim MyDateTime
Do
MyDateTime = Now()
Call logSetLine(0, MyDateTime)
' do something else
Sleep(10)
Loop
end sub
' name "Init" is required, its called automatically during initialization to create menu items
sub Init
Call logAddLine("Press Ctrl+U to start the loop")
addMenuItem "Test-Funktion", "TestMenu", "MyTestLoop", "Ctrl+U"
end sub
Suggestion: If the error message cannot be avoided, you could use "Application.MessageBox". With this MessageBox I can read the error message (the message text) and handle the problem myself. (With the other MsgBoxes I cannot read out the Message Text (e.g. ShowMessage and MessageDlg).
Example: Application.MessageBox('Welcome.', 'Test', MB_OK);
#3 Re: PSPad unicode 5.0.4 (403) English
Posted by: Professor Bernd | Date: 2020-05-23 12:37 | IP: IP Logged
Hello Jan.
It seems that highlighting matching brackets does not work. Can you confirm that?
Bernd.
Edited 1 time(s). Last edit at 2020-05-23 12:38 by Professor Bernd.
#4 Re: PSPad unicode 5.0.4 (403) English
Posted by: pspad | Date: 2020-05-23 12:52 | IP: IP Logged
Professor Bernd:
I know it. It's fixed already. This bug was joined with highlighting occurences.
