You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.3 (371) English
#1 PSPad unicode 5.0.3 (371) English
Posted by: pspad | Date: 2020-01-28 21:49 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.3 (367)
News:
TeX code explorer shows \head
User highlighter - added HEX number attribute
TeX highlighter - added block comments --[[ ]]-- and \starthiding \stophidding. Each comment has different attribute and allows you set different color. As "operator" attribute you can color for \if++, \if+-, \eif, \efi
FTP connection - duplicate connection ends with message "Connection already exists"
problem with editor window name when you open many small files at once
HEX editor - search in HEX - if you paste search string from Excel, you got info that text contains non hex chars (Excell adds line break)
HEX editor - undo after bytes rewriting
HEX editor - find/replace when switching from text and back
#2 Re: PSPad unicode 5.0.3 (371) English
Posted by: gwinkless | Date: 2020-01-29 14:18 | IP: IP Logged
Find-in-files back to old behaviour, thanks (as you know).
Also problem with closing multiple instances seems fixed (was fixed in 367 but I never mentioned it).
#3 Re: PSPad unicode 5.0.3 (371) English
Posted by: Bobf | Date: 2020-01-30 09:05 | IP: IP Logged
many thanks Jan, about the new build, unfortunately there is bad behaviour with the icons on the menu.. some of them are disappear.. you need to hover with the mouse over the icons to bring them back. i can send you a screenshot, as soon that's fixed where can i download the previous built?
many thanks Bob
#4 Re: PSPad unicode 5.0.3 (371) English
Posted by: Bobf | Date: 2020-01-30 09:17 | IP: IP Logged
i went back to pspad503b367 and it works as expected.
rgs Bob
