You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.2 (347) English
Posted by: pspad | Date: 2019-12-20 09:51 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.2 (346)
News
New option in Program settings / System integration - Program icon follows monitor. When PSPad ismoved to another monitor, icon will follows PSPad. But it prevents to have influence of program name on the taskbar.
Find in Files - after click on the Open file ikon in the search result window, file was open empty
TextDiff with file - handled encoding exception via file load
Edited 1 time(s). Last edit at 2019-12-20 09:53 by pspad.
Posted by: PGomersall | Date: 2019-12-20 18:03 | IP: IP Logged
Jan,
Thanks for this: "New option in Program settings / System integration - Program icon follows monitor. When PSPad is moved to another monitor, icon will follows PSPad. But it prevents to have influence of program name on the taskbar." Was looking forward to this forever.
However it currently doesn't seem to work for me:
1) Run PSPad as Admin
2) Set "Program icon follows monitor...
3) Works (while PSPad still open); icon follows monitor, but icon doesn't update to reflect real time status of app.
4) Close PSPad and reopen (either as standard user or admin); setting not set anymore
Pete
After 4 of 5 times trying to set this the entry as Admin, the setting in PSPad_MU.ini sticks, but then opening PSPad the icon doesn't follow the monitor that PSPad is on.
Edited 2 time(s). Last edit at 2019-12-20 18:11 by PGomersall.
Posted by: pspad | Date: 2019-12-20 18:43 | IP: IP Logged
This option is written into PSPAD_MU.ini what is stored next to PSPad.exe
There should be line:
IconFollowsMonitor=1
If PSPad is installed into program files, PSPad must be run ads admin to have rights write into it's folder
This is a reason why there is a red mark before some options.
This file is read in PSPad start, because some options has influence of application behavior in start time, e.g. splashscreen, where to read PSPad.INI file, if from PSPad folder or user profile folder e.t.c.
Posted by: pspad | Date: 2019-12-20 18:45 | IP: IP Logged
PGomersall:3) Works (while PSPad still open); icon follows monitor, but icon doesn't update to reflect real time status of app.
Yes, this is exactly what I wrote. User must choose if icon is more important for him or icon information.
I will check it, but first I need to find any monitor somewhere.
