You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.2 (346) English
Posted by: pspad | Date: 2019-12-15 10:17 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.2 (341)
News
Scripting - new function logIsVisible() returns if LOG window is/isn't visible
Menu Encoding contains new submenu Unicode normalization with 2 items: Canonical Composition and Canonical Decomposition. Accented unicode char can be written as one char containing accent or as 2 chars - basic char followed by accent. These functions provide composition or decomposition of accented chars.
Program settings / Direct edit - new special option UnicodeComposition=1. This settings will automatically make Canonical composition when file is loaded. But note, it will significantly slow down file open speed!
Autocomplete (Ctrl+J) in case of user highlighter with case insensitive keywords offers all words from highlighter definition as upper case
Repaint the ruller if PSPad dragged onto monitor with different DPI
Multihoghlighter for ASP doesn't require space after/before % char
Exception when closing PSpad with deactivated WSH scripting
Posted by: massimobalestra | Date: 2019-12-15 16:29 | IP: IP Logged
This version works, thank you
Posted by: qwerty86 | Date: 2019-12-19 13:01 | IP: IP Logged
Posted by: gmc4by | Date: 2019-12-19 20:43 | IP: IP Logged
Love the tool. Thank you for your work.
I've been having a problem with v5 where the "Open All" button in the search results pane doesn't actually open the files. It opens blank tabs for each file which show the correct filename in the tooltip when hovering with the mouse, but the file is not actually opened.
Posted by: pspad | Date: 2019-12-19 20:50 | IP: IP Logged
gmc4by:Love the tool. Thank you for your work.
Thank you. I can confirm it. Fix will be easy, I will do it as soon as possible,
Posted by: pspad | Date: 2019-12-19 21:24 | IP: IP Logged
Fixed. Available in the next build
Posted by: gmc4by | Date: 2019-12-19 22:25 | IP: IP Logged
Great! Thank you.
