You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.2 (341) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 5.0.2 (341) English
Posted by: pspad | Date: 2019-11-19 08:51 | IP: IP Logged
ejfield:
I'm an getting occasional "Application Error" dialog when I exit PSPAD, first noticed it in 339. It's not very repeatable unfortunately. I cant work out how to paste an image, but it says:
Exception EAccessViolation in module PSPad at 000000000011E499. Access violation at address 000000000011E499 in module 'PSPad.exe'. Read of address 0000000700000000.
I'm using the 64bit version. As far as I can tell, it doesn't do any harm.
Can you tell me what exactly are you doing? Step by step? I need to simulate your problem.
#12 Re: PSPad unicode 5.0.2 (341) English
Posted by: ejfield | Date: 2019-11-19 11:28 | IP: IP Logged
Not really, No! As I said, it's not reliably repeatable. It only happens sometimes, when I click the 'X' top right to close PSPAD. Sometimes I just open a file, look at it, make NO changes, close it again, then I get the message. Other times I don't.
I started with 501en, then copied over 502b341, then 502b341x64.
#13 Re: PSPad unicode 5.0.2 (341) English
Posted by: pourech | Date: 2019-11-20 08:42 | IP: IP Logged
hi
same mistake, same error for me.
When i use "project", i have not this probleme. Even if i m not sure if this is always the case.
I m Under Windows 10 64 bit, VMwareregards
#14 Re: PSPad unicode 5.0.2 (341) English
Posted by: pspad | Date: 2019-11-20 08:56 | IP: IP Logged
64b version of PSPad is still not stable as 32b version.
There is only one reason why to use 64b version - when do you work with big files (hundreds of MB). In any other cases I suggest you to use 32b version. 32b version isn't more slow on 64b operating system and doesn't bring any disadvantages.
#15 Re: PSPad unicode 5.0.2 (341) English
Posted by: ejfield | Date: 2019-11-20 09:52 | IP: IP Logged
OK, fair enough, I'll go back to the 32b version.
It was useful to know that I'm not the only one though!
Thanks for everything.
#16 Re: PSPad unicode 5.0.2 (341) English
Posted by: pspad | Date: 2019-11-20 11:14 | IP: IP Logged
It doesn't mean I won't try to fix this problem. It was only explanation why used / don't used 64b version
#17 Re: PSPad unicode 5.0.2 (341) English
Posted by: pourech | Date: 2019-11-21 10:28 | IP: IP Logged
just for adding one thing : the error doesnt occured if i do :
* click "parametres"
* click "parametres du programme"
* OK
regards
I think i will keep the 64b for big files
#18 Re: PSPad unicode 5.0.2 (341) English
Posted by: Alex | Date: 2019-11-27 11:16 | IP: IP Logged
Hi Jan, WSH not working after update. In settings it apeared as strikethrough text
#19 Re: PSPad unicode 5.0.2 (341) English
Posted by: pspad | Date: 2019-11-27 11:31 | IP: IP Logged
WSH doesn't work in 64b version. In 32b version it should work.
#20 Re: PSPad unicode 5.0.2 (341) English
Posted by: Alex | Date: 2019-11-29 10:47 | IP: IP Logged
i see. it works in 32b. thank you
