You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.2 (339) English
Posted by: pspad | Date: 2019-10-25 13:07 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.2 (321)
News
Find/Replace dialog - added possibility to store profiles
Word under cursor will be returned even cursor is behind the word
Scripting - added variables for getVarValue(): %File% (file name without extension), %Ext% (file extension)
Sample size for code page autodetection was increased from 8 000 to 25 000 chars
Windows Shell script highlighter - added over 100 new keywords
PSPad will inform you when config file save problem occurs.
Function Remove duplicated lines from menu Edit / Line manipulation works with selected text. If no text is selected, it works with whole file
Delete lines with bookmarks - new function in the Search menu or editor Context menu
Dropper - fixed for 64b version
HEX editor - string is checked before paste for allowed hex chars
Find in files - in the search results tabulator disappeared
Windows Shell script - fixed highlighting of words containing "-"
Find in files results - invisible font with black background
Posted by: Professor Bernd | Date: 2019-10-25 15:26 | IP: IP Logged
pspad:News Function Remove duplicated lines from menu Edit / Line manipulation works with selected text. If no text is selected, it works with whole file
... it works with wholw file or line?
Posted by: pspad | Date: 2019-10-25 15:28 | IP: IP Logged
If text is selected, it takes all lines from selection. With no selection it will work with all lines
Posted by: Professor Bernd | Date: 2019-10-25 15:45 | IP: IP Logged
Thank you.
And thank you very much for the new version!
Edited 1 time(s). Last edit at 2019-10-25 15:50 by Professor Bernd.
Posted by: ejfield | Date: 2019-10-28 16:40 | IP: IP Logged
Thanks for the update. I've noticed a couple of things, from an English language point of view:
1. Last item in Search menu appears to be in Czech!
2. Profile line and buttons in find/Replace menu are also in Czech.
Keep up the great job,
Ed
Posted by: pspad | Date: 2019-10-28 17:06 | IP: IP Logged
ejfield:Thanks for the update. I've noticed a couple of things, from an English language point of view:1. Last item in Search menu appears to be in Czech!
Ed
I guess you downloaded x64b version. It contains EXE only without language packs. Add missing files from x32 version.
Posted by: ejfield | Date: 2019-10-29 07:45 | IP: IP Logged
Oh right! So to update to the latest build 64b version, the correct way is to copy over the 32bit version first, then the 64bit version?
Sorry, I didn't notice what it said at the top of this topic!
thanks again
Edited 1 time(s). Last edit at 2019-10-29 07:47 by ejfield.
Posted by: pspad | Date: 2019-10-29 09:08 | IP: IP Logged
ejfield:Oh right! So to update to the latest build 64b version, the correct way is to copy over the 32bit version first, then the 64bit version?
Yes. But for the future I will modify my tool to include all files into x32 and x64 version.
Posted by: Stefan | Date: 2019-10-29 13:43 | IP: IP Logged
mistake in language.ini?
tbLogFont1_Hint := Log window font
instead of
tbLogFont1_Hint=Log window font
Posted by: pspad | Date: 2019-10-29 13:56 | IP: IP Logged
Stefan:mistake in language.ini?tbLogFont1_Hint := Log window font
instead of
tbLogFont1_Hint=Log window font???
Of course mistake. Sorry.
