You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.2 (321) English
#1 PSPad unicode 5.0.2 (321) English
Posted by: pspad | Date: 2019-05-20 18:08 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.2 (319)
News
New code explorer for Z80 assembler (file type FTAssem). New user highlighter Z80 Assembler, which replace existing Z80.
Pascal Code explorer caused program hang up with some specific source content
PHP code beautifier needs existing file. New file caused program hang up
Export highlihted text to RTF
TextDiff - accidental exception on modified line
ISO 8859-2 - fix of code page autodetection
wrong PSPad version (32b vs 64b) in the window title
Oracle SQL highlighter and text literals
#2 Re: PSPad unicode 5.0.2 (321) English
Posted by: Ilya | Date: 2019-05-21 04:39 | IP: IP Logged
confirmed!
#3 Re: PSPad unicode 5.0.2 (321) English
Posted by: Gabriel_ACE | Date: 2019-05-21 14:30 | IP: IP Logged
new spanish languaje
forum.pspad.com
best regarsd!
grinning smiley
#4 Re: PSPad unicode 5.0.2 (321) English
Posted by: Ravelli | Date: 2019-06-06 13:26 | IP: IP Logged
This version tends to crash more often, sadly on unpredictable actions (I use the 32bit version). Some minutes back I opened a CSS file and wanted to scroll down. I missed to click the scroll bar, so I clicked into the text and moved my mouse down. Then PSPad froze and I had to close it via Task Manager.
Interestingly, after such a crash and restarting PSPad, several program settings changed. e.g. ESC to Exit Program, Scroll past EOL and EOF, Trim Trailing Spaces, Wrap (soft) with Right Edge, Tab With, Autocomplete. There might be more which I have not noticed yet.
In the Toolbar, selected folders and files still have an odd background(framing). You can see it in this upscaled screenshot:
www.torsten-funk.de
#5 Re: PSPad unicode 5.0.2 (321) English
Posted by: Andreas | Date: 2019-06-07 14:46 | IP: IP Logged
Ravelli:
I will confirm this. sad smiley
#6 Re: PSPad unicode 5.0.2 (321) English
Posted by: Vany | Date: 2019-06-10 08:42 | IP: IP Logged
Could you be more specific about the files which are crashing you, please?
I use PSPad for mainly LOG files around 15 MB, XML,INI,VBS,CMD from time to time and it works stable.
For home usage I edit PHP, CSS and XML files and without any crashes so long.
(PSPad 5.0.2 (321) x32, W7p x64 cs, W10h x64 cs)
#7 Re: PSPad unicode 5.0.2 (321) English
Posted by: Ravelli | Date: 2019-07-09 10:40 | IP: IP Logged
@Vany: I mostly edit files for websites, like PHP, CSS, MD, TXT, LOG.
Yesterday PSD crashed three or four times while I was editing many PHP files. I first search in project files for certain strings, opened some few files containing these strings, edited those files, saved them. And then on closing tabs via middle-mouse-click PSD crashed. Not always of course, maybe 1-2 times on closing ~100 tabs. And again some several settings in preferences had changed due to crashes.
