You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.2 (321) English
Posted by: pspad | Date: 2019-05-20 18:08 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.2 (319)
News
New code explorer for Z80 assembler (file type FTAssem). New user highlighter Z80 Assembler, which replace existing Z80.
Pascal Code explorer caused program hang up with some specific source content
PHP code beautifier needs existing file. New file caused program hang up
Export highlihted text to RTF
TextDiff - accidental exception on modified line
ISO 8859-2 - fix of code page autodetection
wrong PSPad version (32b vs 64b) in the window title
Oracle SQL highlighter and text literals
Posted by: Ilya | Date: 2019-05-21 04:39 | IP: IP Logged
pspad:Fixes:
confirmed!
Posted by: Gabriel_ACE | Date: 2019-05-21 14:30 | IP: IP Logged
Posted by: Ravelli | Date: 2019-06-06 13:26 | IP: IP Logged
This version tends to crash more often, sadly on unpredictable actions (I use the 32bit version). Some minutes back I opened a CSS file and wanted to scroll down. I missed to click the scroll bar, so I clicked into the text and moved my mouse down. Then PSPad froze and I had to close it via Task Manager.
Interestingly, after such a crash and restarting PSPad, several program settings changed. e.g. ESC to Exit Program, Scroll past EOL and EOF, Trim Trailing Spaces, Wrap (soft) with Right Edge, Tab With, Autocomplete. There might be more which I have not noticed yet.
In the Toolbar, selected folders and files still have an odd background(framing). You can see it in this upscaled screenshot:
www.torsten-funk.de
Posted by: Andreas | Date: 2019-06-07 14:46 | IP: IP Logged
Ravelli:This version tends to crash more often, sadly on unpredictable actions (I use the 32bit version).
I will confirm this.
Posted by: Vany | Date: 2019-06-10 08:42 | IP: IP Logged
Could you be more specific about the files which are crashing you, please?
I use PSPad for mainly LOG files around 15 MB, XML,INI,VBS,CMD from time to time and it works stable.
For home usage I edit PHP, CSS and XML files and without any crashes so long.
Posted by: Ravelli | Date: 2019-07-09 10:40 | IP: IP Logged
@Vany: I mostly edit files for websites, like PHP, CSS, MD, TXT, LOG.
Yesterday PSD crashed three or four times while I was editing many PHP files. I first search in project files for certain strings, opened some few files containing these strings, edited those files, saved them. And then on closing tabs via middle-mouse-click PSD crashed. Not always of course, maybe 1-2 times on closing ~100 tabs. And again some several settings in preferences had changed due to crashes.
Posted by: Greg | Date: 2019-10-16 08:02 | IP: IP Logged
I use 5.0.2 (321) x86.
- LOG windows doesn't show results of "Search / Replace in files...". Font is white color so w're not able to see anything unless we select each line
- GOTO function of code explorer which activate the editor is fixed : bug in 5.0.2 (312) x86
Posted by: pspad | Date: 2019-10-16 08:32 | IP: IP Logged
Greg:HelloI use 5.0.2 (321) x86.
Just checked and didn't meat problem with Search in files log.
PSpad uses font color from Program settings / Colors. Do you use black background with white font?
Posted by: Greg | Date: 2019-10-23 19:39 | IP: IP Logged
pspad:Greg:HelloI use 5.0.2 (321) x86.
Hello, yes i do use black background like i've always done with PSPad and i hadn't that problem before.
In fact, i have the same settings in 5.0.2 (312) and 5.0.2 (321), and i don't have this behavior in 312 :\
