You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.2 (319) English
Posted by: pspad | Date: 2019-04-01 19:30 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.2 (315)
News
Sort (menu Edit) - function allows you sort by lines up to 3 defined columns
Find in files - results - optimalized drawing, added hint to show whole line
FTP - file list parsing - if year is missing and day and month are grater than now, i will consider last year
Code clips - problem with sorting and "ch" letter (slavic languages considers "ch" as one letter)
Code explorer for Autohotkey
Edited 1 time(s). Last edit at 2019-04-02 17:03 by pspad.
Posted by: PGomersall | Date: 2019-04-02 14:28 | IP: IP Logged
Jan,
You have link errors again:
pspad.poradna.net/devel/pspad501b319.zip
pspad.poradna.net/devel/pspad501b319x64.zip
Pete
Edited 2 time(s). Last edit at 2019-04-02 14:30 by PGomersall.
Posted by: pspad | Date: 2019-04-02 17:04 | IP: IP Logged
Fixed. I need to fix my template
Posted by: MadCompie | Date: 2019-04-03 10:52 | IP: IP Logged
Hi Jan,
Me very happy with the FTP dates parsing, works like a charm!
Keep up the good work!
Posted by: pspad | Date: 2019-04-03 11:23 | IP: IP Logged
MadCompie:Hi Jan,Me very happy with the FTP dates parsing, works like a charm!
Glad to hear it
Posted by: PGomersall | Date: 2019-04-04 22:35 | IP: IP Logged
Jan,
I thought I would try the 64 bit version again. However, whenever I open a file on a unc path I usually get an exception when I close the file.
Have gone back 32 bit version.
Pete
Posted by: pspad | Date: 2019-04-05 03:20 | IP: IP Logged
64b version is for testing purposes. It doesn't contains scripting nad HEX editor has some problems yet.
I will try to test UNC path, but I guess the problem will be different.
What type of file you open? Do you use Spell check or anything else?
Any information what can help localize problem is appreciated.
Posted by: PGomersall | Date: 2019-04-05 14:02 | IP: IP Logged
Jan,
I will do some more significant testing and get back to you with info I can obtain.
Pete
Posted by: gwinkless | Date: 2019-04-08 09:45 | IP: IP Logged
Thanks for the continued updates!
Problem not specific to latest version but it's still present in this version: if I have more than one instance of pspad open and I close two of them in quick succession (easiest way is to just log off, but you can reproduce it by closing several with large projects) there's what looks like a locking issue that causes a crash.
Exception description:
Access violation at address 00000000 in module '.exe'. Read of address 00000000.
Exception address: 00000000
Stack list, generated 08/04/2019 10:43:54
<removed, please send such logs by mail>
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.2 (319)
System : Windows 10 Professional x64, Version: 10.0, Build: 4563,
Processor: Intel, Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz, 3100 MHz MMX
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_"
Edited 1 time(s). Last edit at 2019-04-08 14:17 by Stefan.
Posted by: pspad | Date: 2019-04-08 09:55 | IP: IP Logged
gwinkless:if I have more than one instance of pspad open and I close two of them in quick succession
Thank you for this. It really can cause problem, because PSpad shares one config and both instances are trying to write into one config at once.
I will try to handle it.
Maybe some delay and another try to save config can solve it in case of exception.
