You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.2 (319) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 5.0.2 (319) English
Posted by: pspad | Date: 2019-04-01 19:30 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.2 (315)
News
Sort (menu Edit) - function allows you sort by lines up to 3 defined columns
Find in files - results - optimalized drawing, added hint to show whole line
FTP - file list parsing - if year is missing and day and month are grater than now, i will consider last year
Code clips - problem with sorting and "ch" letter (slavic languages considers "ch" as one letter)
Code explorer for Autohotkey
Edited 1 time(s). Last edit at 2019-04-02 17:03 by pspad.
#2 Re: PSPad unicode 5.0.2 (319) English
Posted by: PGomersall | Date: 2019-04-02 14:28 | IP: IP Logged
Jan,
You have link errors again:
pspad.poradna.net/devel/pspad501b319.zip
pspad.poradna.net/devel/pspad501b319x64.zip
Pete
Edited 2 time(s). Last edit at 2019-04-02 14:30 by PGomersall.
#3 Re: PSPad unicode 5.0.2 (319) English
Posted by: pspad | Date: 2019-04-02 17:04 | IP: IP Logged
Fixed. I need to fix my template smiling smiley
#4 Re: PSPad unicode 5.0.2 (319) English
Posted by: MadCompie | Date: 2019-04-03 10:52 | IP: IP Logged
Hi Jan,
Me very happy with the FTP dates parsing, works like a charm!
Keep up the good work!
#5 Re: PSPad unicode 5.0.2 (319) English
Posted by: pspad | Date: 2019-04-03 11:23 | IP: IP Logged
MadCompie:
Hi Jan,
Glad to hear it
#6 Re: PSPad unicode 5.0.2 (319) English
Posted by: PGomersall | Date: 2019-04-04 22:35 | IP: IP Logged
Jan,
I thought I would try the 64 bit version again. However, whenever I open a file on a unc path I usually get an exception when I close the file.
Have gone back 32 bit version.
Pete
#7 Re: PSPad unicode 5.0.2 (319) English
Posted by: pspad | Date: 2019-04-05 03:20 | IP: IP Logged
64b version is for testing purposes. It doesn't contains scripting nad HEX editor has some problems yet.
I will try to test UNC path, but I guess the problem will be different.
What type of file you open? Do you use Spell check or anything else?
Any information what can help localize problem is appreciated.
#8 Re: PSPad unicode 5.0.2 (319) English
Posted by: PGomersall | Date: 2019-04-05 14:02 | IP: IP Logged
Jan,
I will do some more significant testing and get back to you with info I can obtain.
Pete
#9 Re: PSPad unicode 5.0.2 (319) English
Posted by: gwinkless | Date: 2019-04-08 09:45 | IP: IP Logged
Thanks for the continued updates!
Problem not specific to latest version but it's still present in this version: if I have more than one instance of pspad open and I close two of them in quick succession (easiest way is to just log off, but you can reproduce it by closing several with large projects) there's what looks like a locking issue that causes a crash.
Exception description:
Access violation at address 00000000 in module '.exe'. Read of address 00000000.
Exception address: 00000000
Stack list, generated 08/04/2019 10:43:54
<removed, please send such logs by mail>
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.2 (319)
System : Windows 10 Professional x64, Version: 10.0, Build: 4563,
Processor: Intel, Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz, 3100 MHz MMX
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_"
Edited 1 time(s). Last edit at 2019-04-08 14:17 by Stefan.
#10 Re: PSPad unicode 5.0.2 (319) English
Posted by: pspad | Date: 2019-04-08 09:55 | IP: IP Logged
gwinkless:
Thank you for this. It really can cause problem, because PSpad shares one config and both instances are trying to write into one config at once.
I will try to handle it.
Maybe some delay and another try to save config can solve it in case of exception.
