You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.2 (315) English
Posted by: pspad | Date: 2019-03-04 19:09 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.1 (305)
News
Code explorer for ftXML ignores IMAGE tag what is e.g. in SGML without close tag
User highlighter - added Euklid+ support
Hex editor - paste binnary text changed some chars
Hex editor - statusbar informations
On higher DPI menu items used small font (problem of developer tool)
Code explorer for Unix shell script didn't accept function names containing dot
Code explorer - click doesn't focus editor even it was set in Code explorer toolbar button
SpellCheck - excelption sometimes occured
TextDiff - exception sometimes on the last line
Edited 1 time(s). Last edit at 2019-03-04 21:51 by pspad.
Posted by: PGomersall | Date: 2019-03-04 21:20 | IP: IP Logged
Jan - you have typo in your download links; still showing 501 not 502
Posted by: pspad | Date: 2019-03-04 21:52 | IP: IP Logged
Thank you, fixed
Posted by: MadCompie | Date: 2019-03-08 11:14 | IP: IP Logged
Hi!
I found something weird in the FTP explorer (connected with a Linux).
A file is last changed 2018-10-02 11:22:32
When using the FTP explorer in PSPad and sorting all files by date, this file from 2018-10-02 becomes the first in line?
It says "2019-10-02"... so indeed that is > today but this is not correct.
Perhaps this is due to Linux behaviour?
When listing the files in Linux ("ls -l") it says "Oct 2 11:22" ...
So no year, because it is not relevant (we KNOW that 2019 is not possible, so it MUST be 2018, otherwise 2017 would be displayed).
When using "stat" it says correctly:
Access: 2019-03-08 11:54:50.571168848 +0100
Modify: 2018-10-02 11:22:32.715676145 +0200
Change: 2018-10-02 11:22:32.715676145 +0200
Perhaps it could be possible to obtain the dates in PSPad using the FTP RAW command "MDTM" ?
when I do that in the FTP explorer I obtain the correct date:
mdtm <file>
213 20181002092232
Posted by: pspad | Date: 2019-03-08 11:54 | IP: IP Logged
I don't know if you use MLSD for file attributes in FTP connection
Try open FTP connection settings and uncheck Old file listing. If available, it will use MLSD command for file list.
Before MLSD, all FTP servers used it's own proprietary format. There was no standard.
You can too press LIST button on the left in FTP LOG window (Ctrl+L)
You will show what is returned by FTP server.
Posted by: gwinkless | Date: 2019-03-10 11:48 | IP: IP Logged
pspad:Fixes:
Thanks for the update!
I can't believe I didn't realise this before (I've been doing a lot of web development which doesn't require the compile function) but the problem with double-click not focusing on the editor from the search windows (I guess it's the same with the code explorer here?) is also the same problem on the Log window :(
Geoff
Posted by: gwinkless | Date: 2019-03-12 13:17 | IP: IP Logged
I wrote:also the same problem on the Log window :(
Well either you already fixed this in this version (I hadn't downloaded it yet cos I wasn't at work until today but just assumed since it wasn't listed in the changes) or I was having some sort of moment. It works just fine in (315). Please feel free to delete last message.
Geoff
Edited 1 time(s). Last edit at 2019-03-12 13:18 by gwinkless.
Posted by: pspad | Date: 2019-03-12 13:19 | IP: IP Logged
It's info for the others too
Posted by: MadCompie | Date: 2019-03-13 11:28 | IP: IP Logged
Hi, I checked and indeed MLSD is not supported so that could be the reason.
Thx for your response!
Posted by: pspad | Date: 2019-03-13 11:39 | IP: IP Logged
If you press button LIST in the LOG window, it will put raw listing into log. You can send me it as mail attachment - all spaces and formating are important and add name of your FTP (I mean name of the software).
If you tell me what file name shows in PSpad wrong dat, I can try to modify parsing
