You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.1 (310) English
Posted by: pspad | Date: 2019-02-17 15:46 | IP: IP Logged
New full version 5.0.0 was published. Available at:
www.pspad.com
Posted by: Gabriel_ACE | Date: 2019-02-18 16:41 | IP: IP Logged
Hi jan!
you are doing exelent work!!
I will do the same And I share with the comunity this:
COBOL.DEF
this have all examples for synatx - updated 18/02/2019
but I need to share another bug and example that how pspad may be work
all this is in this file check it
LINK:
www.mediafire.com
BEST REGARDS!!!
Posted by: PGomersall | Date: 2019-02-19 16:23 | IP: IP Logged
Hi Jan, I just wonder if you wanted to comment on where you generally are with getting the 64 bit version in a state ready for general release?
Maybe link the 310 64 bit dev version in this thread?
Posted by: jofrie | Date: 2019-02-19 19:06 | IP: IP Logged
will there be a portable version again?
Posted by: pspad | Date: 2019-02-19 20:25 | IP: IP Logged
There is a portable version.
If you want portable version on FossHub, they changed behavior and there can be one published file in time only, so I can't publish installer + portable version together.
Anyway, Installer allows you install PSpad as portable too + you can download portable version from PSpad download page.
Posted by: pspad | Date: 2019-02-19 20:28 | IP: IP Logged
PGomersall:Hi Jan, I just wonder if you wanted to comment on where you generally are with getting the 64 bit version in a state ready for general release?
I am sorry, but 64b version has still some problems and I havn't enough time to fix it yet. As you can see, I spare some time to fix some problems in past weeks. Everything is about the time...
Posted by: garbuya | Date: 2019-02-20 18:33 | IP: IP Logged
Portable version on Download page points to the Windows Installer
Please fix this link
Posted by: pspad | Date: 2019-02-20 18:39 | IP: IP Logged
garbuya:Portable version on Download page points to the Windows Installer
Portable version and installer pointed both to the the same FossHub location. In the past there were ZIP + installer for download.
But as I explained, FossHub doesn't give possibility to have 2 files for download as before.
I will change target to the same location as portable mirror.
Posted by: garbuya | Date: 2019-02-20 19:12 | IP: IP Logged
Is it 32 or 64 bit?
Starting logo, Title and About all shows 32
Also, please post developer version 310 -- it is 305 now
Thank you
Posted by: pspad | Date: 2019-02-20 19:29 | IP: IP Logged
garbuya:Is it 32 or 64 bit?
Starting logo, Title and About all shows 32Also, please post developer version 310 -- it is 305 now
Thank you
Hello. Full version is x32 only. There are problems in x64 to be released.
There is no reason to publish 310 developer version if there is 310 full version. When next developer build will be ready, the version will increase. I think you are able to wait week or 2 for next developer build
