You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.1 (289) English
Goto Page: 1 2 Next
#1 PSPad unicode 5.0.1 (289) English
Posted by: pspad | Date: 2018-12-15 17:28 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.1 (287)
News
CSS highlighter - added large amount of missing keywords
SAS code parser - added macro support
Log lines display problem with active URL highlightter
Taskbar program icon will appear on screen where prgoram window is (Jochen Heinelt)
Windows Shell script - ^ char breaks meaning of special chars
Windows Shell script - cmd as file extension was highlighted as keyword
Windows shell script - matching bracket highlight with echo command
Cobol highlighter - keywords with underscore
PSPad 64 - SpellCheck exceptions
#2 Re: PSPad unicode 5.0.1 (289) English
Posted by: Gabriel_ACE | Date: 2018-12-17 14:05 | IP: IP Logged
the new changes are working well
BUT I found a bug... check bug section smiling smiley
forum.pspad.com
#3 Re: PSPad unicode 5.0.1 (289) English
Posted by: programmer9 | Date: 2019-01-10 11:46 | IP: IP Logged
Build 289 still has the problem where the triangles at the start of the lines in the Find in Files Results tab have to be double-clicked to expand or collapse the entries for the files - earlier versions (up to and including build 271) would expand and collapse the entries with a single left-click (which is the way that Windows Explorer, amongst other programs, works).
Would it be possible to revert to the earlier (and perhaps more conventional) single left-click to expand/collapse the entries please?
Many thanks
Richard
#4 Re: PSPad unicode 5.0.1 (289) English
Posted by: pspad | Date: 2019-01-10 19:22 | IP: IP Logged
programmer9:
Many thanks
Richard
I found a problem and fixed it.
#5 Re: PSPad unicode 5.0.1 (289) English
Posted by: pspad | Date: 2019-01-10 19:40 | IP: IP Logged
Gabriel_ACE:
forum.pspad.com
I can't confirm
#6 Re: PSPad unicode 5.0.1 (289) English
Posted by: Gabriel_ACE | Date: 2019-01-11 20:37 | IP: IP Logged
what do you need from me to confirm my problem?
smiling smiley
Edited 1 time(s). Last edit at 2019-01-11 20:37 by Gabriel_ACE.
#7 Re: PSPad unicode 5.0.1 (289) English
Posted by: pspad | Date: 2019-01-12 05:42 | IP: IP Logged
For my case the problem occurs when you use global minimize with Win+D.
#8 Re: PSPad unicode 5.0.1 (289) English
Posted by: Gabriel_ACE | Date: 2019-01-14 15:16 | IP: IP Logged
thats is a good answer grinning smiley
#9 Re: PSPad unicode 5.0.1 (289) English
Posted by: pspad | Date: 2019-01-14 16:05 | IP: IP Logged
The inmportant for me is I am able to simulate it. Now I need to find problem solution
#10 Re: PSPad unicode 5.0.1 (289) English
Posted by: gwinkless | Date: 2019-01-23 11:40 | IP: IP Logged
New version now shows "PSPad (32) - project name" in the task bar, as opposed to the project name first. This is a real pain for me because I have multiple taskbar icons (ungrouped) for different open projects that I can click on quickly and easily and I now can't see easily which is which.
Can you revert? Or at least add an option to choose?
Or have I messed up a setting somewhere?
Thanks
Edited 3 time(s). Last edit at 2019-01-23 11:46 by gwinkless.
Goto Page: 1 2 Next
