You are here: PSPad forum > Developer forum - new builds > Re: Tabs color: limitation on number
#1 Tabs color: limitation on number
Posted by: brolx | Date: 08/28/2018 09:03 | IP: IP Logged
I'm maybe using PSPad too much winking smiley
I've reached a max number (buffer size I suppose) and I cannot assign a color to a tab anymore (actually I can do it but it's lost when closing the program).
Is it possible to increase this buffer?
Another possibility (but it would obviously be better to have both) would be to allow to assign a color to all files belonging to a folder/tree. That's typically what I (manually) use.
Thanks a lot
#2 Re: Tabs color: limitation on number
Posted by: pspad | Date: 08/28/2018 09:16 | IP: IP Logged
Program settings / Files and dirs.
Do you have checked [x]Remember file state?
Buffer is unlimited, each file is remebered individually in the file PSCache5.bin
The condition - you need to have rights to write in this file. E.g. when you unpack portable version into program files, PSPad has no rights to write there and no settings will be remembered
#3 Re: Tabs color: limitation on number
Posted by: brolx | Date: 09/06/2018 12:04 | IP: IP Logged
[x]Remember file state is checked (I unchecked, aply, rechecked, apply).
PSCache5.bin is updated at each close but the new colors I set are not remembered. This is why I thought it was a limit on the number
#4 Re: Tabs color: limitation on number
Posted by: pspad | Date: 09/06/2018 13:12 | IP: IP Logged
I will check it.
