You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.1 (281) English
Posted by: pspad | Date: 2018-08-02 12:00 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.0 (277)
News
Code explorer for XML will expand first 2 levels only automatically. Speed up for big XML files
Code explorer for PHP - classes are expanded automatically
Code explorer - if left docked, page is automatically activated
New Code explorer for KiBasic (ftKiBasic file type for user highlighter)
Project tree - nodes indentation
Editor window flickering when switching
Fixed problem with protocol highlighting (mail, URL, ...) when file with with long lines
ESC key closes Code explorer window
Import from RTF to HTML (HTML menu)
Insert file - fixed problem with BOM included code pages
Posted by: Gabriel_ACE | Date: 2018-08-02 17:33 | IP: IP Logged
code explorer is missing (((((
and when I resize left panel the text editor windows don't fix its size
T______T
WHY!!!!!!?!?!?!?!? T_____T
Edited 1 time(s). Last edit at 2018-08-02 18:20 by pspad.
Posted by: pspad | Date: 2018-08-02 18:20 | IP: IP Logged
Code explorer is missing?
Do you have Code explorer docked on the left or on the right? I see it in both cases.
I am sorry, but I am not able to confirm your second report about size of the window.
When I change size of the left panel, the size of the editor window changes.
When you need to help, please write report by the way I would be able to simulate it.
Posted by: Gabriel_ACE | Date: 2018-08-02 18:36 | IP: IP Logged
Posted by: Gabriel_ACE | Date: 2018-08-02 18:47 | IP: IP Logged
in english TOO but is less frecuently
Edited 1 time(s). Last edit at 2018-08-02 18:50 by Gabriel_ACE.
Posted by: Gabriel_ACE | Date: 2018-08-02 19:09 | IP: IP Logged
pspad:Code explorer is missing?
When I change size of the left panel, the size of the editor window changes.When you need to help, please write report by the way I would be able to simulate it.
docked on the right
Posted by: pspad | Date: 2018-08-03 06:44 | IP: IP Logged
It's really strange. I was able to get it, now I need to find what causes this strange behavior
Posted by: pspad | Date: 2018-08-03 06:59 | IP: IP Logged
I will publish new buld today, can you check it please?
Posted by: Gabriel_ACE | Date: 2018-08-03 12:59 | IP: IP Logged
yes!
I will be here all day
Edited 1 time(s). Last edit at 2018-08-03 13:00 by Gabriel_ACE.
Posted by: pspad | Date: 2018-08-03 13:28 | IP: IP Logged
Its out already
