You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (271) English
Posted by: pspad | Date: 2018-04-03 08:57 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.0 (267)
News
Code page change on open file will mark file as "modified"
HTML highlighter - added keyword "picture"
User convertors direction
Ctrl+MouseWheel changes font size but scroll pages too
Copy/Duplicate line - when selection ends on the start of next line
Posted by: Gabriel_ACE | Date: 2018-04-03 13:46 | IP: IP Logged
THZ!!!!!!
Posted by: Gabriel_ACE | Date: 2018-04-06 19:27 | IP: IP Logged
HI!!!
when we generate a brand using the new button in the search menu (Crtl+F).
Is there any way to navigate through the brands with a keyboard shortcut?
Like
AltGr+Page down ----> going down
AltGr+Page up ----> going up
if not Pleeeeeeeeaseeeeeee Add it
Best regards!!
Posted by: pspad | Date: 2018-04-07 07:45 | IP: IP Logged
From the begin you can go through bookmarks with Alt+Up/down
Alt+Left - set unnumbered bookmark
Alt+Right - delete bookmark
Posted by: tmtisfree | Date: 2018-04-07 09:35 | IP: IP Logged
Hello Jan,
In this version font scaling in the menu seems broken as menu text is almost unreadable on my 2160x1440 (at 150%) screen (left is v266, right is v271, both screenshots with a x3 zoom):
Also, since some version size of some toolbars is inconsistent. As you can see on the following screenshot I have arranged the good looking toolbars on the first line and the smaller ones on the second line which is creating problems when trying to rearrange them:
Finally I sent you a new translation file for French on February 24, could you please add it to the next release.
Thanks,
TMTisFree
Edited 1 time(s). Last edit at 2018-04-07 09:35 by tmtisfree.
Posted by: Gabriel_ACE | Date: 2018-04-09 13:25 | IP: IP Logged
pspad:From the begin you can go through bookmarks with Alt+Up/down
THZ!!!!!!!!!!
THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ THZ
Posted by: Gabriel_ACE | Date: 2018-04-11 13:52 | IP: IP Logged
Hi
I was thinking about the new button to find and put mark in the file
could you add the same action for all OPEN FILES?
as programer many times I need to find the same variable in diferent sources codes.
Posted by: gwinkless | Date: 2018-04-12 13:53 | IP: IP Logged
pspad:Fixes:
Problem from last version with "create bookmarks" not working is fixed, thanks
Posted by: pspad | Date: 2018-04-16 12:23 | IP: IP Logged
tmtisfree:In this version font scaling in the menu seems broken as menu text is almost unreadable on my 2160x1440 (at 150%) screen (left is v266, right is v271, both screenshots with a x3 zoom):
Thanks,
TMTisFree
The reason was found (very long time spent to search the reason). There was a bug in the Delphi 10.2 and menu item size. I made own fix to make menu HighDPI ready. Delphi 10.2.3 brings fix but it causes this behavior with my fix. Now all works OK now and I don't need to take care of menu item font size
Posted by: tmtisfree | Date: 2018-04-16 19:39 | IP: IP Logged
pspad:The reason was found (very long time spent to search the reason). There was a bug in the Delphi 10.2 and menu item size. I made own fix to make menu HighDPI ready. Delphi 10.2.3 brings fix but it causes this behavior with my fix. Now all works OK now and I don't need to take care of menu item font size
Fantastic, good work!
