You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (266) English
Posted by: pspad | Date: 2018-02-22 19:46 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.0 (261)
News
Perl highlighter - partly implemented the 'q' function
Oracle highlighter - partly implemented the 'q' function
Open file from internet - works with HTTPS
OpenSSL libraries was updated to 1.0.2n version
Perl - matching bracket fix in case escaped bracked was in code
Posted by: michael.hollstein | Date: 2018-02-26 10:20 | IP: IP Logged
Edit / Selection Type / Column Selection doens't work in 266
Posted by: pspad | Date: 2018-02-26 11:05 | IP: IP Logged
michael.hollstein:Edit / Selection Type / Column Selection doens't work in 266
What exactly doesn't work?
If you have enabled option Alt sets column mode, selection is made with mouse together with ALT key pressed. Without ALT key mouse will reset selection to normal block. But selection still work for cursor keys.
If you prefer switch block and select with mouse, switch off option in program settings / Editor 1
Posted by: michael.hollstein | Date: 2018-02-26 12:10 | IP: IP Logged
[ ] Alt sets column mode (off) works for me. Thank you.
Posted by: kimgkimg | Date: 2019-10-22 20:56 | IP: IP Logged
pspad:michael.hollstein:Edit / Selection Type / Column Selection doens't work in 266What exactly doesn't work?
This must have changed as the default setting in v5. I recall the default behavior to be select selection type from the menu and then it stays until you select a different one from the menu. However, now that I know you can do this ALT thing, I like it much better. Thank you!
