You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (266) English
#1 PSPad unicode 5.0.0 (266) English
Posted by: pspad | Date: 02/22/2018 19:46 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.0 (261)
News
Perl highlighter - partly implemented the 'q' function
Oracle highlighter - partly implemented the 'q' function
Open file from internet - works with HTTPS
OpenSSL libraries was updated to 1.0.2n version
Perl - matching bracket fix in case escaped bracked was in code
#2 Re: PSPad unicode 5.0.0 (266) English
Posted by: michael.hollstein | Date: 02/26/2018 10:20 | IP: IP Logged
Edit / Selection Type / Column Selection doens't work in 266
#3 Re: PSPad unicode 5.0.0 (266) English
Posted by: pspad | Date: 02/26/2018 11:05 | IP: IP Logged
michael.hollstein:
What exactly doesn't work?
If you have enabled option Alt sets column mode, selection is made with mouse together with ALT key pressed. Without ALT key mouse will reset selection to normal block. But selection still work for cursor keys.
If you prefer switch block and select with mouse, switch off option in program settings / Editor 1
#4 Re: PSPad unicode 5.0.0 (266) English
Posted by: michael.hollstein | Date: 02/26/2018 12:10 | IP: IP Logged
[ ] Alt sets column mode (off) works for me. Thank you.
