You are here: PSPad forum > Developer forum - new builds > Re: Open file with mouse click in explorer not possible
Posted by: khagaroth | Date: 2018-02-19 18:40 | IP: IP Logged
The last test build works.
Posted by: PGomersall | Date: 2018-02-19 18:52 | IP: IP Logged
Just need the language file updating now?
Posted by: pspad | Date: 2018-02-19 20:21 | IP: IP Logged
I will finish Perl highlighter fix and next build will contains updated language files
Posted by: ivo | Date: 2018-02-19 20:43 | IP: IP Logged
khagaroth:The last test build works.
same here. Thank you!
Posted by: pspad | Date: 2018-02-19 20:58 | IP: IP Logged
I thank you all of you. You helped me with testing.
Posted by: AndreasW | Date: 2018-02-20 09:24 | IP: IP Logged
Another problem: The option "Files and Dirs -> Same as active document" seems not to work. When Pressing Ctrl+O, the Open dialog will NOT show the directory of the active document, but another directory. This used to work correctly in previous versions.
Posted by: pspad | Date: 2018-02-20 09:41 | IP: IP Logged
AndreasW:Another problem: The option "Files and Dirs -> Same as active document" seems not to work. When Pressing Ctrl+O, the Open dialog will NOT show the directory of the active document, but another directory. This used to work correctly in previous versions.
It's my fault. I tested themes and forgot to uncomment open dialog settings.
Posted by: aGerman | Date: 2018-02-20 18:37 | IP: IP Logged
Thanks Jan! The problem with opening another file drove me crazy yesterday Now it works again. Although your workaround to initially open PSPad in a normal window makes that the tool bar is split in two lines and keeps being split after the window was maximized.
Steffen
Posted by: Andreas | Date: 2018-02-20 19:24 | IP: IP Logged
Many thanks to all for figuring this out.
Posted by: Gabriel_ACE | Date: 2018-02-21 12:34 | IP: IP Logged
pspad:Another test build, without message boxes already:There is something strange deep in the Delphi form handling. I had to use workarround.
please update main link in the begin of the post
Best Regards!
