You are here: PSPad forum > Developer forum - new builds > Re: Open file with mouse click in explorer not possible
#11 Re: Open file with mouse click in explorer not possible
Posted by: pspad | Date: 2018-02-19 10:51 | IP: IP Logged
khagaroth:
I am sorry, but I am not able to símulate it.
Do you use multiinstance? That works. But with single instance (ie opening everything in one window) it doesn't. For example if I use F4 in Total Commander repeatedly, it will open only the first file and then do absolutely nothing on subsequet uses.
No, I don't use multinstance.
Just tested with Total Commander and F4. I didn't met any problem with file opening sad smiley
#12 Re: Open file with mouse click in explorer not possible
Posted by: pspad | Date: 2018-02-19 10:52 | IP: IP Logged
Check if there is only one PSPad instance in memory please.
Do you have PSPad.exe in long file path with spaces?
Edited 1 time(s). Last edit at 2018-02-19 10:53 by pspad.
#13 Re: Open file with mouse click in explorer not possible
Posted by: AndreasW | Date: 2018-02-19 11:00 | IP: IP Logged
There's only one PSPad instance in memory.
No.
Btw, I'm using the 64 bit version of pspad.
#14 Re: Open file with mouse click in explorer not possible
Posted by: Andreas | Date: 2018-02-19 11:50 | IP: IP Logged
I also use the single instance.
My Path is
C:\Portable\PortableApps\PSPadPortable\PSPad.exe
ps Is there scripting within the 64er version meanwhile?
Edited 1 time(s). Last edit at 2018-02-19 11:50 by Andreas.
#15 Re: Open file with mouse click in explorer not possible
Posted by: ivo | Date: 2018-02-19 12:30 | IP: IP Logged
Same problem here, with TotalCommander.
I suspect it's related with Multi User Environment (and PSPad_MU.ini)
I tried to shift out that file (from pspad folder), then closing PSPad and all was ok.
Trying again with PSPad_MU, problem reappears.
I hope it helps
Bye
Ivo
#16 Re: Open file with mouse click in explorer not possible
Posted by: pspad | Date: 2018-02-19 12:31 | IP: IP Logged
Thank you
#17 Re: Open file with mouse click in explorer not possible
Posted by: pspad | Date: 2018-02-19 13:00 | IP: IP Logged
Here is test build:
When you open file (context menu or TC or ..) and PSPad is running PSPad will show you message with file and information "Message sent".
Running instance sould show you information "Message received" with name of the file.
Can you test it please?
#18 Re: Open file with mouse click in explorer not possible
Posted by: khagaroth | Date: 2018-02-19 13:22 | IP: IP Logged
I'm getting message sent dialogs with the full file path, but no message received dialogs at all.
#19 Re: Open file with mouse click in explorer not possible
Posted by: ivo | Date: 2018-02-19 13:27 | IP: IP Logged
Opening PSPad directly with a file, i don't see any message but file is open.
Trying to open an other file, i see message with filename, but file isn't open.
Of course i tried with PSPad_MU.ini present (MultiUser=1)
Ivo
...sorry: I don't see Message "Received"
Edited 1 time(s). Last edit at 2018-02-19 13:28 by ivo.
#20 Re: Open file with mouse click in explorer not possible
Posted by: AndreasW | Date: 2018-02-19 13:42 | IP: IP Logged
khagaroth:
Same here.
