You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (231) English
#1 PSPad unicode 5.0.0 (231) English
Posted by: pspad | Date: 05/24/2017 18:58 | IP: IP Logged
Download links (5.4 MB):
PSPad 64 bit version preview without scripting support
Changes to 5.0.0 (227)
PSPad x64 Hexeditor - access violation in some cases
Duplicate line function
Edited 1 time(s). Last edit at 05/25/2017 06:24 by pspad.
#2 Re: PSPad unicode 5.0.0 (231) English
Posted by: crimson | Date: 05/25/2017 05:20 | IP: IP Logged
Thanks for fixing duplicate line function.
#3 Re: PSPad unicode 5.0.0 (231) English
Posted by: Macari | Date: 05/25/2017 14:34 | IP: IP Logged
Good work!
I found this one: Characters like ↪ not working in pspad. Is this a bug? Format is set utf8. I see only a rectangle. In Microsoft Notepad its working fine.
Edited 1 time(s). Last edit at 05/25/2017 14:34 by Macari.
#4 Re: PSPad unicode 5.0.0 (231) English
Posted by: pspad | Date: 05/25/2017 16:54 | IP: IP Logged
It depends of used font. Set same font in Notepad as you use in PSPad.
#5 Re: PSPad unicode 5.0.0 (231) English
Posted by: Macari | Date: 05/26/2017 11:16 | IP: IP Logged
It is. I use in both "Consolas" with same font-size.
See www2.pic-upload.de
#6 Re: PSPad unicode 5.0.0 (231) English
Posted by: PGomersall | Date: 05/26/2017 22:14 | IP: IP Logged
Jan, getting an access violation on odd occasions I close a file by middle clicking the tab. This is usually the last tab open but it does not always occur. This locks PSPad completely and there is no access to the error dialog to send it back to you. The only way to exit is to kill PSPad. This is with the x64 version. Next time I will take a screen shot if that is useful. I will send more details if a pattern becomes apparent.
Keep up the good work.
Pete
#7 Re: PSPad unicode 5.0.0 (231) English
Posted by: starfort_jp | Date: 05/27/2017 06:19 | IP: IP Logged
Thank you for the update.
I noticed that the star on encoding setting is fixed and unchangeable(always ANSI default.) How can I change the character encoding on 5.0.0?
#8 Re: PSPad unicode 5.0.0 (231) English
Posted by: pspad | Date: 05/27/2017 06:38 | IP: IP Logged
starfort_jp:
Ctrl+click in the encoding menu oe default encoding in the program settings / files
#9 Re: PSPad unicode 5.0.0 (231) English
Posted by: starfort_jp | Date: 05/27/2017 07:01 | IP: IP Logged
I confirmed it.
Thank you very much.
