You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (203) English
#1 PSPad unicode 5.0.0 (203) English
Posted by: pspad | Date: 2017-05-07 19:45 | IP: IP Logged
Download links (5.4 MB):
PSPad 64 bit version preview without scripting support
Changes to 5.0.0 (191)
News
Code explorer speed up
Import from CSV - rewrited to standard CP support
Find in Files - rewrited to standard CP support
File type plugin can be batch file (*.BAT). You can use it to transfotrm parameters for any command line tool. More info in file .\plugins\FileType\Readme.txt.
Added support to gather text from PDF file using PDFToText (http://www.foolabs.com/xpdf/) when you open PDF in PSPad. This way uses BAT file type plugin
Added support for users who fill FTP configuration file with external scripts. Now is possible to write FTP connection passwords in plain text form using variable PlainPassword=readable_password. PSPad will encrypt all passwords when you use FTP client and will remove PlainPasswords lines.
Cobol Code explorer and COPY on the start of line in free form syntax
Smart char completion - skipping of the closing char
User highlighter with TextInfo comment style and char @
#2 Re: PSPad unicode 5.0.0 (203) English
Posted by: Andreas | Date: 2017-05-08 14:27 | IP: IP Logged
Pspad freezes when opening the code explorer. Went back to (187).
