You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (191) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 5.0.0 (191) English
Posted by: pspad | Date: 2017-05-02 13:23 | IP: IP Logged
Download links (5.4 MB):
PSPad 64 bit version preview without scripting support
Changes to 5.0.0 (187)
News
Backup/Restore configuration changed from CAB to ZIP and added new files (Program settings / Backup)
TexInfo support in user highlighter
Optional possibility run compiler on background (not as default). Has sense for the long compiler run.
SpellCheck - some buttons like Skip all wasn't functional
Sort dialog - reverse string, sort by line length
closing splitted editor window caused exception in come cases
#2 Re: PSPad unicode 5.0.0 (191) English
Posted by: AndreasW | Date: 2017-05-02 15:17 | IP: IP Logged
Thank you very much for the 64 bit version. I've tested it with a large log file, and it worked fine (without a crash). Just one note: The function Ctrl+F --> List is much slower than the same function in Notepad++ with the same large logfile. (I haven't measured it exactly, but I would say the difference in speed is about factor 5.)
#3 Re: PSPad unicode 5.0.0 (191) English
Posted by: Stefan | Date: 2017-05-03 06:53 | IP: IP Logged
Sort dialog - ........., sort by line length
Is fixed.
#4 Re: PSPad unicode 5.0.0 (191) English
Posted by: Stefan | Date: 2017-05-03 06:57 | IP: IP Logged
I still don't get what this option does.
I have:
Lange Zeile Eins Lange Zeile Eins Lange Zeile Eins Lange Zeile Eins
Zeile 2 Zeile 2 Zeile 2 Zeile 2
Zeile 3 Zeile
Line
I execute:
Sort dialog - Asc - Reverse string
I get:
Zeile 3 Zeile
Line
What is the use of this?
Where is the thread where it was asked for this feature?
THX
#5 Re: PSPad unicode 5.0.0 (191) English
Posted by: vbr | Date: 2017-05-03 07:59 | IP: IP Logged
this is usually called "rückläufige Sortierung" in German - the sort is performed from the end of the "words".
This should actually be a separate type of sort options, as it is still combinable with other string-based (ANSI, ASCII, Locale).
This sorting form can be useful for some linguistic analyses, e.g. regarding word endings, suffixes, compounds, possibly even rhyme-finding etc. Cf. e.g. the following listing of wikipedia entries:
"https://de.wiktionary.org/w/index.php?title=Kategorie:Rückläufige_Wörterliste_(Deutsch)&pagefrom=R"
(In your sample, there are trailing spaces in some lines, which influence the sort order.)
hth,
Edited 2 time(s). Last edit at 2017-05-03 08:03 by vbr.
#6 Re: PSPad unicode 5.0.0 (191) English
Posted by: pspad | Date: 2017-05-03 08:14 | IP: IP Logged
Reverse string in the short:
change char order of string: abcd -> dcba and sort it.
#7 Re: PSPad unicode 5.0.0 (191) English
Posted by: Stefan | Date: 2017-05-03 08:35 | IP: IP Logged
Wow, danke vbr, I never had solved that on my own.
;;Translate Reverse string
rReverse_Caption=Rückläufig / Rückwärts
I Have original:
Character C
Number 8
String DA
String FA
Word EB
Word FB
I Execute Sort Asc Reverse String
I get:
Number 8
String DA
String FA
Word EB
Word FB
Character C
Sorted from back, from last sign to first:
8 rebm
AD gnirtS
AF gnir
BE droW
BF dro
C retc
#8 Re: PSPad unicode 5.0.0 (191) English
Posted by: human | Date: 2017-05-04 11:58 | IP: IP Logged
Just a note (I don't know if this was different in last full version):
If highlighter settings are changed the code explorer should auto-reload (at least for COBOL [switching between fixed-form and free-form reference-format).
News
Forgive me for not knowing: but how can I use this? I've opened a .texi file, the highlighter (in the bottom bar) shows "Text". Then I click on Settings-User Highlighter, a dialog comes up where I can open Texinfo.INI and see it, along with the file extension ".texi) but the highlighter doesn't change.
#9 Re: PSPad unicode 5.0.0 (191) English
Posted by: human | Date: 2017-05-04 12:09 | IP: IP Logged
And two minor issues with the COBOL code explorer:
a) in free-form reference format it is possible to have "COPY yourinclude." at column 1 but it isn't recognized there (if it is in column 2 it is shown in the code explorer). All other items beginning in column 1 are shown.
b) in the identification "folder" we have an entry "program-id." this is nice but it would be better to additional have the actual id in (especially when you work with multi-program sources).
Thank you for this Editor!
#10 Re: PSPad unicode 5.0.0 (191) English
Posted by: pspad | Date: 2017-05-04 13:49 | IP: IP Logged
human:
News
TextInfo uses new comment style - this is a support what was added.
You need to assign new TextInfo synax file in highlighter settings.
