You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (187) English
Posted by: pspad | Date: 2017-04-24 06:50 | IP: IP Logged
Download links (5.2 MB):
Changes to 5.0.0 (182)
News
TeX code explorer - added \def and \define
File explorer - rename functionality in file context menu is back
Code explorer remebers expanded/collapsed nodes for refresh
Log content wasn't loaded from the file after compilation
TeX code parse - \paragraph out of hierarchy
PHP code explorer - wrong label detection
Log extension was associated to TeX extension and causes exception when Code explorer was active
Posted by: crimson | Date: 2017-04-25 11:41 | IP: IP Logged
I still can see the Code Explorer Windows shows incorrect result in C/C++. See below code piece for instance.
test
VOID
FuncA (
IN AAA *aaa
if (AAAA) {
BBBB;
FuncB (
CCCC
if (DDDD) {
EEEE;
FuncB (
CCCC
if (FFFF) {
GGGG;
FuncB (
CCC
The result in Code Explorer Windows is:
FuncA (
FuncB (
FuncB (
FuncB (
The expectation should be only FuncA (
Please help to check this. Let me know if you need more information.
Posted by: pspad | Date: 2017-04-25 11:47 | IP: IP Logged
I havn't made changes in C++ code parser yet.
Edited 1 time(s). Last edit at 2017-04-25 11:48 by pspad.
Posted by: Stefan | Date: 2017-04-26 06:48 | IP: IP Logged
Bug report:
5.187 "Edit > Sort... > Line length"
didn't sort by length anymore.
5.163 did have sorted correctly.
5.187 does something,
but it's no correct result by "Line length".
What should do "Edit > Sort... > Reverse string"?
Is that a "reverse" sort by "Line length"?
If yes, then it didn't work either.
And why should we need that?
Other options didn't have a reverse feature not either.
And we have "Edit > Lines Manu > Swap lines in block" for that.
EDIT: and we can use ASC and DESC options for the wanted sort order.
Edited 1 time(s). Last edit at 2017-05-03 06:59 by Stefan.
Posted by: Stefan | Date: 2017-04-26 07:15 | IP: IP Logged
CPBatchConvert, didn't show a "done" message
or like that, but should, isn't it?
And I didn't see a "is in process" animation
on the button of that dialog?
Looks like there is a control for that?
I tested with the PSPad language folder.
Posted by: Stefan | Date: 2017-04-26 07:21 | IP: IP Logged
ACHTUNG D e u t s c h
Can somebody with German language file
and FTP connection check this translation please:
Kann jemand mit Deutscher Sprachedatei
und FTP-Verbindung bitte mal die Übersetzung testen:
;;Translate Upload file(s)
mFTPUploadFile_CAption=Datei(en) Upload
oder passt da auch das vom Platz her:
mFTPUploadFile_CAption=Datei(en) hochladen
Danke.
Posted by: Andreas | Date: 2017-04-26 08:50 | IP: IP Logged
Geht bei mir. "Datei(en) hochladen". Getestet in 5.0.0 186.
Edited 1 time(s). Last edit at 2017-04-26 08:50 by Andreas.
Posted by: pspad | Date: 2017-04-26 09:13 | IP: IP Logged
Sort dialog fix will be available in the next build.
Posted by: Stefan | Date: 2017-04-26 10:11 | IP: IP Logged
Andreas:Geht bei mir. "Datei(en) hochladen". Getestet in 5.0.0 186.
THX Andreas.
Und dass passt ins Konzept,
... versteht man den Befehl an dieser Stelle was der macht?
Anders gesagt: passt "Datei(en) hochladen" zu dem was
der Befehl ausführt und was man davon erwartet?
Danke
Posted by: Andreas | Date: 2017-04-26 12:10 | IP: IP Logged
Ja, tut es. Der Text erscheint bei Mouse-Over über dem Button und im Kontextmenü in der FTP-Dateiliste. Bei Klick öffnet sich das Windows Dateiauswahlfenster und man kann eine oder mehrere Dateien zum Upload auswählen. Der Upload funktioniert auch.
