You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (156) English
Goto Page: 1 2 Next
#1 PSPad unicode 5.0.0 (156) English
Posted by: pspad | Date: 2017-03-25 11:15 | IP: IP Logged
Download links (2.9 MB):
Changes to 5.0.0 (147)
News
C++ added new keywords from 9.9 and 11 version
Cobol added 114 new keywords (GNU Cobol, Open Cobol)
OutOfMemory exception when "big file" is closed
Few fix from received exception logs
Handled "UpdateTabIcons" exception when more windows are closed
#2 Re: PSPad unicode 5.0.0 (156) English
Posted by: Stefan | Date: 2017-03-28 14:32 | IP: IP Logged
Deutsch.ini is on its way by separate eMail.
- Typo:
JSON pretty print reformar
JSON pretty print reformat
- Need help:
where can I find that string in the GUI?
137: ;;Translate JSON pretty print reformar
138: aJsonReformat_Caption=JSON Formater
492: ;;Translate New PSPad version %s is available.\nDo you want to visit web page for download?
493: rs_NewVersionAvailable=Neue PSPad-Version %s verfügbar.\nMöchten Sie die Webseite zum Herunterladen besuchen?
630: ;;Translate Check now
631: bUpdateCheckNow_Caption=Jetzt überprüfen
642: ;;Translate Anonymous application usage tracking
643: cAppAnalytics_Caption=Anonymisiertes tracken der Programmverwendung
801: ;;Translate Check program updates
802: cUpdateCheck_Caption=Regelmäßig auf Updates prüfen
803: ;;Translate Check include developer versions
804: cUpdateCheckDevel_Caption=Auch Entwicklerversionen anzeigen
885: ;;Translate Check for update interval in days:
886: lUpdateInterval_Caption=Updateintervall, Tage:
887: ;;Translate Last update check:
888: lUpdateLastCheck_Caption=Letzte Überprüfung:
910: ;;Translate Update
911: rs_tabUpdates=Updates
#3 Re: PSPad unicode 5.0.0 (156) English
Posted by: pspad | Date: 2017-03-28 14:50 | IP: IP Logged
Json formater in the format menu
Analytics - last item in program settings / program 2
Updates as new item in program settings list
#4 Re: PSPad unicode 5.0.0 (156) English
Posted by: sandrosilveira | Date: 2017-03-28 18:04 | IP: IP Logged
COBOL Syntax highlighting Problems (colorization of 'Reserved Words'):
Screenshot running in 5.0.0 (156):
Screenshot running in previous release (147):
My Color Scheme:
I'll wait for a fix to release for our beta testers...
Thanks!
#5 Re: PSPad unicode 5.0.0 (156) English
Posted by: pspad | Date: 2017-03-28 18:10 | IP: IP Logged
This is problem of setting Cobol areas.
Go to highlighter settings / Specification and set proper area values you use in your implementation.
#6 Re: PSPad unicode 5.0.0 (156) English
Posted by: sandrosilveira | Date: 2017-03-28 18:25 | IP: IP Logged
Hi Jan, I didn't change any settings between the two releases, and running with the same configuration in PSPAD r156 the colorization is not working.
My highlighter settings area values to both releases:
Try yoursef with this sample code (click in 'quote' to get with correct spaces indentation):
identification division.
program-id. hello.
environment division.
configuration section.
special-names.
decimal-point is comma,
console is crt.
data division.
working-storage section.
01 w-var pic is x(01) value is spaces.
procedure division.
main-paragraph.
*>-> Comment line
display "hello world".
stop run.
Thank you!
Edited 1 time(s). Last edit at 2017-03-28 18:26 by sandrosilveira.
#7 Re: PSPad unicode 5.0.0 (156) English
Posted by: mali_zeeko | Date: 2017-03-28 19:25 | IP: IP Logged
PsPad 5.0.156 crashes while opening C++ source code:
Faulting application name: PSPad5.exe, version: 5.0.0.156, time stamp: 0x58d64230
Faulting module name: ntdll.dll, version: 10.0.10586.672, time stamp: 0x580efaf8
Exception code: 0xc0000005
Fault offset: 0x0008b80a
Faulting process id: 0x18dc
Faulting application start time: 0x01d2a703d5a09d9b
Faulting application path: C:\app\PSPad\PSPad5.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
After a few crashes in a row, PsPad.ini gets deleted, and all settings are gone sad smiley
#8 Re: PSPad unicode 5.0.0 (156) English
Posted by: mali_zeeko | Date: 2017-03-28 19:33 | IP: IP Logged
Thank you for the new C++ keywords. I noticed that alternatives for logical and bitwise operators are not recognized: and, bitor, or, xor, compl, bitand, and_eq, or_eq, xor_eq, not, not_eq
#9 Re: PSPad unicode 5.0.0 (156) English
Posted by: pspad | Date: 2017-03-28 19:33 | IP: IP Logged
Is there any PSPad exception or this Windows error only?
mali_zeeko:
#10 Re: PSPad unicode 5.0.0 (156) English
Posted by: mali_zeeko | Date: 2017-03-28 19:35 | IP: IP Logged
mali_zeeko:
This error only. I've searched in WER but found only this.
I can set procdump on PsPad to get more data.
Goto Page: 1 2 Next
