You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (136) English
Posted by: pspad | Date: 2017-03-18 19:01 | IP: IP Logged
Download links (2.9 MB):
Changes to 5.0.0 (122)
News
Added anonymous program usage program tracking. You can switch it off in the program settings / Program 1. For now in developer builds only.
Code pages - added ISO 8859-2 autodetection
PSPad remembers height of File explorer file list box
PHP code explorer - added labels
HTML highlighter - added highlight matching MAIN
Hex Editor - Search/replace has been rewritten, fixed problem with 00 in search/replace
PSPad checks new version on start. Parameters are available in the Program settings / Check update
PSPad will activate Multiuser environment switch if detect user unpack it manually into Program files folder
Pascal Code explorer - fixes related to block comment and directives
Clipboard monitor and shortcut problems (Del e.t.c.)
Hex editor - rewrited Search/Replace. Fixed problem with 00 in replace string
SpellCheck caused exception if stay active end you close all files and open new
MarkCurrentFileTab option (Special settings) works again
Batch CP convert causes exception in case PSPad was stored in Program Files and started as portable - recent entries in dialog.
PSPad update check doesn't load settings into Program settings dialog
Posted by: ok1 | Date: 2017-03-19 07:53 | IP: IP Logged
PSPad.exe in new archive is the same as in the 133 archive so it still reports the version as 133.
Posted by: pspad | Date: 2017-03-19 08:49 | IP: IP Logged
I am sorry. I know it's second time already, but it isn't intentional.
Package was updated and now it should contains 136 build.
Posted by: myf | Date: 2017-03-19 15:45 | IP: IP Logged
So Changes to previous developer bild 5.0.0 (133) are
pspad:News
PSPad will activate Multiuser environment switch if detect user unpack it manually into Program files folderFixes:
Posted by: pspad | Date: 2017-03-19 15:56 | IP: IP Logged
I intentionally let there changes from build 122
Posted by: ok1 | Date: 2017-03-20 00:13 | IP: IP Logged
Thanks. Downloaded new archive & all appears to be good.
Posted by: crimson | Date: 2017-03-20 09:42 | IP: IP Logged
"Download and install latest full version first! "
What's the latest full version? Is it 4.6.2 (2750)?
I tried to download 4.6.2 (2750) and replace with 5.0.0 (136) but got some error when open program and the language is not in English as default.
Posted by: pspad | Date: 2017-03-20 10:09 | IP: IP Logged
crimson:"Download and install latest full version first! "What's the latest full version? Is it 4.6.2 (2750)?
Developer build package contains subvolders. Maybe you unpacked all into one folder...
Here is content of developer build archive:
Posted by: crimson | Date: 2017-03-20 11:00 | IP: IP Logged
Thanks for promptly response. Yes, I am familiar with updating the develop build. I also tried to only replace with the Pspad.exe but got the same incorrect result. I also tried to download 5.0.0 (136) from two servers but it's the same.
Maybe I miss something. So just want to confirm the latest full version is 4.6.2 (2750) because I expect there is a 5.0.0 full version official release.
Best regards.
Posted by: vbr | Date: 2017-03-20 11:17 | IP: IP Logged
crimson:Thanks for promptly response. Yes, I am familiar with updating the develop build. I also tried to only replace with the Pspad.exe but got the same incorrect result. I also tried to download 5.0.0 (136) from two servers but it's the same.
Maybe I miss something. So just want to confirm the latest full version is 4.6.2 (2750) because I expect there is a 5.0.0 full version official release.Best regards.
the expected full version as a base for version-5 betas is indeed 4.6.2 (2750) from the download page
www.pspad.com
or currently:
The content of the beta-versions from archive files:
should be copied to the folder with that full version, while overwriting the files with same names and keeping the directory structure.
(Some files, which are specific for the version-5, have different paths there, e.g. "Language" (instead of "Lang" in the previous versions).
If you are still seeing errors on startup, after a usual update as mentioned, there might be some other circumstances (Maybe permissions for the program folder, some antivirus interference or others...)
hth,
