You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2671) English
Goto Page: 1 2 Next
#1 PSPad unicode 4.6.0 (2671) English
Posted by: pspad | Date: 2015-09-12 09:43 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2669)
News
(removed) PSPadStarter - delete pspadstarter.exe, isn't necessary already. For previous build users - open PSpad settings / System integration. uncheck and check "open TXT files" and confirm OK.
PSPad start speed up optimalization
MarkCurrentFileTab - new parameter in special settings (default 0). If you set it to 1, PSPad will underline active file tab.
Cursor Edge - new functionality what shows vertical line similar to RightEdge on the cursor position. New option in the Program settings / Editor 1, OFF as default
InfoBasic - new code parser for user highlighter
File open - restore state - bookmarks behind the end of the file won't be restored
Search in files - problem with search directory history and state
BAT highlighter - fix of the case %( in string, Call and another fixes
Print - folder name is shortened to prevent file stamp ovewrite
PHP highlighter - fixed problem /*/
#2 Re: PSPad unicode 4.6.0 (2671) English
Posted by: pythonui | Date: 2015-09-14 03:29 | IP: IP Logged
Nice feature but is there any possibility to change colour of underline of current tab (I think blue is there right now) ?
Thanks
Edited 1 time(s). Last edit at 2015-09-14 03:30 by pythonui.
#3 Re: PSPad unicode 4.6.0 (2671) English
Posted by: pspad | Date: 2015-09-14 12:59 | IP: IP Logged
MarkCurrentTab option is useful for Windows without themes, cause it's hard to see current file tab.
The color is now same as font - it prevents mark visibility for paople with nonstandard colors. Is it really so important to create another option? Cause this option is in special settings, color should be in special settings too and there will be necessary to enter color in hexadecimal format.
#4 Re: PSPad unicode 4.6.0 (2671) English
Posted by: pythonui | Date: 2015-09-15 03:21 | IP: IP Logged
If possible in colours section in program settings ?
Thanks
Edited 1 time(s). Last edit at 2015-09-15 03:21 by pythonui.
#5 Re: PSPad unicode 4.6.0 (2671) English
Posted by: PascalR | Date: 2015-09-16 07:27 | IP: IP Logged
Jan,
"Show vertical line on cursor position" doesn't work for me.
Regards
Pascal
#6 Re: PSPad unicode 4.6.0 (2671) English
Posted by: pspad | Date: 2015-09-16 07:46 | IP: IP Logged
What does it mean doesn't work for you? You don't see the vertical line?
Check right edge color in the program settings / Colors. You won't see it if right edge color has same color as windows background
#7 Re: PSPad unicode 4.6.0 (2671) English
Posted by: m2u_germany | Date: 2015-09-16 07:52 | IP: IP Logged
At first it didn’t work for me either. I had to restart the program to see it.
Another issue with this feature: Real tabs seem to be considered as one single space even if it was set to multiple ones. Therefore if the cursor is preceeded by one or more tabs wider than one space the position of cursor and line don’t match.
#8 Re: PSPad unicode 4.6.0 (2671) English
Posted by: crimson | Date: 2015-09-18 08:26 | IP: IP Logged
I do not see this new feature either, even after change the right edge color. What's the expected behavior? Is there picture for demo?
Edited 1 time(s). Last edit at 2015-09-18 08:28 by crimson.
#9 Re: PSPad unicode 4.6.0 (2671) English
Posted by: pspad | Date: 2015-09-18 09:40 | IP: IP Logged
This is the functionality. The first vertical line moves acording to cursot position
ctrlv.cz
#10 Re: PSPad unicode 4.6.0 (2671) English
Posted by: crimson | Date: 2015-09-18 11:19 | IP: IP Logged
Thanks for the information. I can see it now after clicking the ruler.
Goto Page: 1 2 Next
