You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2657) English
#1 PSPad unicode 4.6.0 (2657) English
Posted by: pspad | Date: 2015-04-07 19:10 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2656)
News
External file diff tool (Program settings / Text Difference). Is possible to set up externa file compare tool which will be used instead of the integrated one.
UTF-8 surrogate pair support
Statusbar doesn't show unicode chars correctly. Now it shows correctly surrogate pairs too
Highlighter settings - document comment settings was limited to 2 chars
If file wasn't open as UTF-8 (invalid characters), PSPad will open it as ANSI
Highlight syntax limit wasn't accepted when file was restored on PSpad start
Default current line color is used if highlight syntax is off
#2 Re: PSPad unicode 4.6.0 (2657) English
Posted by: Bobf | Date: 2015-04-07 19:36 | IP: IP Logged
Hi Jan,
the pspad460b2657.zip shows after apply the beta code a version 4.5.0 instead of 4.6.0.
The pspad460b2656.zip shows still the correct version.
Can you please correct this?
many thanks.
Bob
Edited 1 time(s). Last edit at 2015-04-07 19:40 by Bobf.
#3 Re: PSPad unicode 4.6.0 (2657) English
Posted by: Freeman | Date: 2015-04-07 19:44 | IP: IP Logged
This build cannot recognize itself as the last, because his number is 4.5.0.2657.
#4 Re: PSPad unicode 4.6.0 (2657) English
Posted by: pspad | Date: 2015-04-07 20:08 | IP: IP Logged
I am sorry.
I rebuilded and reuploaded current 2657 build with 4.6.0 version.
#5 Re: PSPad unicode 4.6.0 (2657) English
Posted by: Bobf | Date: 2015-04-07 20:10 | IP: IP Logged
Thanks Jan,
i downloaded it again and the new package solved the problem. the version is now correct.
Bob
#6 Re: PSPad unicode 4.6.0 (2657) English
Posted by: toralf | Date: 2015-04-07 21:42 | IP: IP Logged
Thank you for the diff tool and doc comment fix.
I'll test it soon.
Ciao
toralf
