You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2653) English
#1 PSPad unicode 4.6.0 (2653) English
Posted by: pspad | Date: 2015-03-09 10:36 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.9 (2652)
News
When language is changed in Program settings, PSPad will show localization help request if language file contains more than 10 untranslated strings.
File tab context menu - fixed translation of File tab color
#2 Re: PSPad unicode 4.6.0 (2653) English
Posted by: Billy | Date: 2015-03-09 12:48 | IP: IP Logged
Hello Jan,
can you please get rid of that thick horizontal line below the tab bar? I think it was introduced in build 2529.
Here's a screenshot:
Regards,
Billy
#3 Re: PSPad unicode 4.6.0 (2653) English
Posted by: pspad | Date: 2015-03-09 12:59 | IP: IP Logged
I tried it, but I don't know where it cames from. When I will have more time, I will investigate more.
#4 Re: PSPad unicode 4.6.0 (2653) English
Posted by: pspad | Date: 2015-03-09 20:16 | IP: IP Logged
I know what causes this line. I set parameter for file tab control what prevents flickering when you resize or move window. But the side effect is this line.
It's easy to switch it back, but file tabs will flick.
#5 Re: PSPad unicode 4.6.0 (2653) English
Posted by: target232 | Date: 2015-03-15 20:33 | IP: IP Logged
I have problem with this new build PSPad 4.6.0 build 2563
After upgrading from stable version, suddenly file associations is not working properly. I have Highlight Settings for ASP highly customised and each time I double click *.asp file this highlighter is applied. In new version after I double clicked *.asp file highlighter is starting in "HTML multilighter" settings. If I just switch new exe with old one *.asp highlighter recognizes *.asp and start ASP highlighter.
#6 Re: PSPad unicode 4.6.0 (2653) English
Posted by: pspad | Date: 2015-03-15 21:31 | IP: IP Logged
go to program settings / multihighlighter and check if correct highlighter is set for ASP. How big are your ASP files?
#7 Re: PSPad unicode 4.6.0 (2653) English
Posted by: Billy | Date: 2015-03-19 11:40 | IP: IP Logged
Jan, looks like you've found a fix/workaround for the thick line issue in build 2655. Thanks! smiling smiley
#8 Re: PSPad unicode 4.6.0 (2653) English
Posted by: pspad | Date: 2015-03-19 12:04 | IP: IP Logged
Billy:
Yes, but it brings back file tab flickering when you resize window.
