You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2652) English
Posted by: pspad | Date: 2015-03-08 11:25 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2600)
News
Current File tab highlight - new option HighlightCurrentFileTab in [special settings] section (Program settings / Direct edit button) with values 1/0 (ON/OFF)
zvýraznění aktuální záložky souborů - nová volba HighlightCurrentFileTab v sekci [special settings] v nastavení programu přímá editace s hodnotami 1/0 (zapnuto/vypnuto)
new function Open in new instance - opens current window in new PSPad instance. Menu Window or file tab context menu. You can assign shortcut in program settings / KeyMap under Window section
Special settings section in Program settings will be always sorted alphabetically. Is necessary to use OK or Apply button once.
problem with close tab with splitted window
ABB code explorer - fixed function detection
Posted by: Freeman | Date: 2015-03-08 19:24 | IP: IP Logged
Great thanks to tab highlight setting, Jan!
