You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2528) English
#1 PSPad unicode 4.5.9 (2528) English
Posted by: pspad | Date: 2015-02-11 11:46 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2527)
News
TiDy - if TiDycfg.ini file contains [Check Only] section, parameters will be used for function from menu HTML/Check HTML (Ctrl+F10)
New script for beautify VB script code from Marcus Roming. Available from Script menu
problem with line behind the last char with fonts like courier new
Ctrl+DblClik - select text inside quotes
FTP client another fix for MLSD command. For FTP authors: read and respect RFC documents!
