You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2527) English
Posted by: pspad | Date: 2015-02-09 08:23 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2525)
News
PHP highlighter - added new keywords for PHP 5.6
Numeric base calculator - small changes like whole binary number is visible, is possible copy with Ctrl+C, ..
Restore last open file - new function (menu file / open special) with default shortcut Ctrl+Alt+Z
fixed Drag/drop image into editor (HTML) with pressed CTRL key
