You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2525) English
#1 PSPad unicode 4.5.9 (2525) English
Posted by: pspad | Date: 2015-01-04 20:32 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2521)
News
Fixed problem with empty PSPad help in case PSpad is started from network drive as multiuser. In this case local copy of the help is created in %AppData%\PSpad folder.
WWW Preview and missing cursor
FTP log - copy content to clipboard using right mouse
File tabs - file name with extreme font DPI settings
Matching brackets and keywords on Win 8.1 system and above with active wrap lines
fixed "google" Java scripts recognition in HTML multihighlighter
#2 Re: PSPad unicode 4.5.9 (2525) English
Posted by: mgutt | Date: 2015-01-28 21:43 | IP: IP Logged
Any chance to get this for search as well?
"Search/replace - replace include new line"
#3 Re: PSPad unicode 4.5.9 (2525) English
Posted by: carbonize | Date: 2015-01-31 16:53 | IP: IP Logged
Use regular expressions.
Carbonize
#4 Re: PSPad unicode 4.5.9 (2525) English
Posted by: francheu | Date: 2015-02-03 09:50 | IP: IP Logged
The search/replace in files has a strange behaviour.
Replacing a string a first time is OK.
But for the second time (replacing another string), the strings are detected and said to be replaced, but the display seems to be not updated, because if I close PSPad and reopen it the changes have been applied...
François
Edited 1 time(s). Last edit at 2015-02-03 09:50 by francheu.
#5 Re: PSPad unicode 4.5.9 (2525) English
Posted by: francheu | Date: 2015-02-03 10:00 | IP: IP Logged
Another problem is when displaying non-printable characters.
The spaces are sometimes displayed twice (see line 23), and the printable characters can even be inverted ! (see line 16)
François
#6 Re: PSPad unicode 4.5.9 (2525) English
Posted by: pspad | Date: 2015-02-03 12:29 | IP: IP Logged
Go to program settings / direct edit button
Change variable: OldSpecialChars=1
It's in the [Special settings] section where you are places when you call direct edit.
#7 Re: PSPad unicode 4.5.9 (2525) English
Posted by: francheu | Date: 2015-02-04 07:22 | IP: IP Logged
OK, it works now, thanks !
(Sorry I should have searched into the forum, the answer is already there...)
François
