You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2517) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.9 (2517) English
Posted by: pspad | Date: 2014-11-11 19:26 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2513)
News
FTP - new option for SSL/TLS - Prot P or Prot C settings
scripting - new function topLineIndex([integer]):integer - sets top line or returns index of first visible line in editor window
scripting - new function linesInWindow(): integer - returns number of lined in editor window
scripting - new function setWaitCursor([boolean]) - sets/resets mouse cursor to hourglass. Usage for longer running scripts.
Ctrl + Left mouse Click in editor selects whole word
Program settings / Tools - new option Search in Files - remember Replace setting
PHP - continue comment function
Editor area flickering
#2 Re: PSPad unicode 4.5.9 (2517) English
Posted by: PascalR | Date: 2014-11-12 11:47 | IP: IP Logged
Hi Jan,
i tested the new script functions and they work flawlessly.
Thank you very much for your support!
Regards
Pascal
#3 Re: PSPad unicode 4.5.9 (2517) English
Posted by: pspad | Date: 2014-11-12 12:21 | IP: IP Logged
PascalR:
Hi Jan,
Regards
Pascal
I am glad it works for you. smiling smiley
#4 Re: PSPad unicode 4.5.9 (2517) English
Posted by: c3k | Date: 2014-11-13 08:53 | IP: IP Logged
ctrl+click selection is driving me crazy
could you please make it optional?
#5 Re: PSPad unicode 4.5.9 (2517) English
Posted by: Macari | Date: 2014-11-13 20:44 | IP: IP Logged
Great! Thank you very much. smiling smiley
#6 Re: PSPad unicode 4.5.9 (2517) English
Posted by: ugc | Date: 2014-11-13 23:30 | IP: IP Logged
Thank you smiling smiley
#7 Re: PSPad unicode 4.5.9 (2517) English
Posted by: DenTNT | Date: 2014-11-22 18:30 | IP: IP Logged
Thanks for Unicode support.
I have a question about it.
I have installed Windows 7 x64 and I have set English language for non-Unicode programs as default system language. So when I open PSPad with Russian language ini-file, I see Russian menu names - this is as intended
But, when I press right mouse button for the PSPad contex menu, I see garbage (non Russian letters).
Is Context menu non-Unicode?
Edited 2 time(s). Last edit at 2014-11-22 18:31 by DenTNT.
#8 Re: PSPad unicode 4.5.9 (2517) English
Posted by: DenTNT | Date: 2014-11-22 19:04 | IP: IP Logged
Added screenshot.
As you can see, all setting items are in incorrect codepage.
But Russian.ini is in UTF8 codepage AND all menu items in Russian shows normal!!!
#9 Re: PSPad unicode 4.5.9 (2517) English
Posted by: Freeman | Date: 2014-11-23 01:41 | IP: IP Logged
Please check the "Default language for non-Unicode programs" setting at Control Panel. It should be set to "Russian".
If it already set to Russian, maybe it is old unattended Windows installation bug, still presents in Windows 7 (as I see). It affects non-Unicode Delphi/VCL applications. Under XP, it can be solved by changing Windows theme to any other, then return back. Under modern Windows, you can see here.
#10 Re: PSPad unicode 4.5.9 (2517) English
Posted by: pspad | Date: 2014-11-23 07:22 | IP: IP Logged
The solution is usually to set language to English, restart and set it back to Russian.
This is bug caused by preinstalled OS images from bigger computer sellers.
