You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2500) English
Posted by: pspad | Date: 2014-09-02 07:58 | IP: IP Logged
Download links (2.7 MB):
code.fosshub.com
Changes to 4.5.8 (2485)
News
System context menu integration - DLL extension (John Brandwood - sourceforge.net)
Find/Replace dialog is sizable (width)
FTP - added MLSD command detection. If command isn't supported, PSPad will use old LIST command
File Changes detection was extended to file size too. Checked is timestamp + file size
File browser - fixed wrong file size for files bigger 4GB
Code explorer for PERL - fixed dashed sub name
FTP - New file cut out additional underscores.
Posted by: PGomersall | Date: 2014-09-03 15:20 | IP: IP Logged
Jan,
It looks like you have not resolved the locking file issue I mentioned in Re: PSPad unicode 4.5.8 (2485) English #23; is that correct?
Pete
Posted by: pspad | Date: 2014-09-03 15:59 | IP: IP Logged
If there isn't mentioned in fixed, it means it isn't fixed. Will be fixed in future build. I was forced by users to publish new PSPad release. Development will continue.
Posted by: Neil | Date: 2014-09-04 02:34 | IP: IP Logged
Hi Jan,
Sorry for the confusion with my request.
I wanted this window to be resizeable:
Thanks
Neil
Posted by: pspad | Date: 2014-09-04 06:11 | IP: IP Logged
Neil:Hi Jan,Sorry for the confusion with my request.
Thanks
This is a standard windows dialog. I will try to look at it.
Posted by: pspad | Date: 2014-09-04 11:44 | IP: IP Logged
PGomersall:Jan,
Pete
Now is fixed, will be available in the next build
Posted by: PGomersall | Date: 2014-09-04 19:33 | IP: IP Logged
Jan,
Just did an upgrade on 2 machines to 2500 (x64). On one the context menu dll works the other it didn't. Just done a completely clean install of 4.5.8 the dll context menu didn't work either. Even after reboot.
Not sure what is going on, but seems to be an issue; can you look into or offer suggestions to troubleshoot?
Pete
Posted by: pspad | Date: 2014-09-04 20:23 | IP: IP Logged
Is there pspshellx64.dll in PSPad folder?
If yes, go to program settings / System and choose DLL (not registry) way and check option you want to have in context menu. If the options is checked, uncheck it, check it again and confirm.
The shell DLL what is installed depends of your system (32 or 64 bit)
Posted by: PGomersall | Date: 2014-09-05 19:32 | IP: IP Logged
pspad:Is there pspshellx64.dll in PSPad folder?
If yes, go to program settings / System and choose DLL (not registry) way and check option you want to have in context menu. If the options is checked, uncheck it, check it again and confirm.The shell DLL what is installed depends of your system (32 or 64 bit)
Yes to all above but context menu on only 1 out of 5 systems. The 1 that works is running Server 2012 R2 the 4 that are not working Windows 8.11 x64.
Pete
Edited 1 time(s). Last edit at 2014-09-05 19:33 by PGomersall.
