You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2463) English
Posted by: pspad | Date: 2013-11-10 18:19 | IP: IP Logged
Download links (2.7 MB):
31.31.78.126
www.dropbox.com
Changes to 4.5.8 (2462)
News
Code explorer will keep his state (expanded nodes) after refresh
Find matching bracket result position depends of the program settings / Editor 2 - Search result option
HTML highlighter - added highlighting of pair tags center and font
Select tag function was extended - now is possible to select tag from the end of pair tag too
Auto completion - new option in program settings / Editor 2 - is possible to disable insert item with Space bar
Code format dialog - added Apply button. Existing OK button got standard behavior - confirm close dialog.
Search replace dialog with was increased
File information function / Number of chars shows all chars from ascii 33, instead of letters only in previous version
Posted by: massimobalestra | Date: 2013-11-12 14:31 | IP: IP Logged
The Find matching bracket result position I asked works great!! thanks Jan
Posted by: Bolla | Date: 2013-11-18 13:11 | IP: IP Logged
Thank you!
Now I can have the old space key behaviour!
Posted by: linusklan | Date: 2013-11-22 17:22 | IP: IP Logged
Not working under linux, the some error that 4.5.7 version,
"Internal Error: SyncHotKeyPosition Failed ("&Format" <> "&Formát")."
only 4.5.6 and smaler working perfect.
Posted by: Bolla | Date: 2013-11-29 09:38 | IP: IP Logged
Uhmm... Just found this, don't know if it's a new feature or what...
Autocomplete works with keys like like ( ! ' and others...
Is it possible to have autocomplete working only for TAB key or have this configurable at will?
Thanks,
Luca
Posted by: pspad | Date: 2013-11-29 10:09 | IP: IP Logged
I will modify it. It will be configurable in 2 steps:
mode 1 - it will autocomplete with any non char key
mode 2 - it will complete with tab or enter key only
Posted by: gwinkless | Date: 2013-12-06 11:06 | IP: IP Logged
PSPad is still saving ANSI-codepage files twice in this version, as discussed here: forum.pspad.com
Posted by: pspad | Date: 2013-12-06 12:55 | IP: IP Logged
gwinkless:
It wasn't fixed yet. I am sure you didn't read it in any change. I am looking for the problem.
Posted by: pspad | Date: 2013-12-06 14:06 | IP: IP Logged
gwinkless:
I run processmonitor utility and there is only one write for ANSI same as for UNICODE format. I agree, arround it is several files access - checking if file exists before writing, gather of the current attributes, current time.
When attribute is set to hidden, read only or system, PSPad needs to reset it.
When you save file, PSPad must return attributes back
If set Don't change time, PSPad must return datetime stamp for the file
On the final, PSPad reads current time stamp for proper file change detection.
I know, it can generate lot of filoe access and slow down save process on slow network drives. I will try to reduce number of accesses
Posted by: padfox | Date: 2014-01-12 18:51 | IP: IP Logged
Hello Jan,
when I press [Alt], I don't see any underscores of the main menu items (shortcuts). And I enabled that these keys are shown with underscores permanently (there is an option in the Windows OSs). That worked in my last version 4.5.7 (2450). Main problem are menu items with the same starting char, which can't be accessed directly. And I need the shortcuts for automation.
Many thanks and greetings
padFox
