You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2457) English
Posted by: pspad | Date: 2013-05-29 20:31 | IP: IP Logged
Download links (2.7 MB):
pspad.siliconhill.cz
www.dropbox.com
Changes to 4.5.8 (2455)
News
Highlighter settings - added possibility define highlighter based current line collor
Oracle highlighter - added keywords TRIGGERS, INSTANCES, DEGREE
HTML highlighter - highlighting of pair tags DL, DT, DD
New Code explorer for Structured Text language (ftSTL file type in User highlighter definition)
Autocomplete window disappear when symbol chars is inserted
Hex editor - wan't possible to open file with unicode chars in name
Fixed OEM files content load
CSS inline reformat - in some cases was selector name changed to lowercase
Send unicode file name into running PSPad instance
C++ code explorer doesn't show content of NAMESPACE
Fortran code explorer - recognition of function with filetypes e.g. real*4
Run Clip function (Shift+Space) works again
Posted by: mceps | Date: 2013-05-30 21:58 | IP: IP Logged
Run Clip working fine now, thanks.
Thank you,
Cristian
Edited 1 time(s). Last edit at 2013-05-30 21:59 by mceps.
Posted by: mceps | Date: 2013-05-31 19:06 | IP: IP Logged
Hi Jan,
Actually, there's still a problem with the Run Clip in latest version, for example I have a clip entered like this:
[index | index]
index(string|,var,1)
in version 2441, if I type "in" and hit space nothing happens, the clip is not auto-run, as it shouldn't be because the clip code is "index", but in 2557 if I type "in" and hit space, or even just "i" and hit space it will auto-run this clip.
Thank you,
Cristian
Posted by: Freeman | Date: 2013-05-31 19:07 | IP: IP Logged
Thanks for OEM fix, Jan.
But I'm afraid it's still incomplete. Now PSPad properly opens a file with OEM block characters, but drops them on file saving. I've used these characters for an example.
Posted by: gwinkless | Date: 2013-06-21 15:12 | IP: IP Logged
Problem: I have always used shortcut "altS->s" to go "search"->"search in files"; now in this version when I do "altS->s", it selects the "Scripts" menu item.
My guess is that because Scripts has changed to &Scripts (instead of S&cripts (?)) windows no longer allows the ->s to choose the "&Search in files" menu item in the "Search" menu?
Posted by: gwinkless | Date: 2013-06-21 15:22 | IP: IP Logged
gwinkless:Problem: I have always used shortcut "altS->s" to go "search"->"search in files"; now in this version when I do "altS->s", it selects the "Scripts" menu item.My guess is that because Scripts has changed to &Scripts (instead of S&cripts (?)) windows no longer allows the ->s to choose the "&Search in files" menu item in the "Search" menu?
I fixed for myself by changing
mScripts_Caption=Scripts
to
mScripts_Caption=S&cripts
in Lang\English.ini
Odd thing is that previous version I had didn't have this, so I wonder if the menu handling has changed?
Edit: that's not right though, cos alt-c brings up the colour picker :(
Edited 1 time(s). Last edit at 2013-06-21 15:27 by gwinkless.
Posted by: Fred | Date: 2013-06-24 11:57 | IP: IP Logged
It seems that Alt+S does not drop open the Search menu.
Alt+S CR s does work but looks a little stange and different from standard behaviour...
For myself i use Alt+F for Search and replace in files ( menu Settings, Program settings, Key Map ).
Posted by: pspad | Date: 2013-06-24 12:12 | IP: IP Logged
There is automatic hot key assigning. It's easy to modify it and assign S for search menu.
Open .\Lang\english.ini
look for: mFind_Caption
modify it to: mFind_Caption=&Search
Posted by: AxeBlack | Date: 2016-03-13 10:15 | IP: IP Logged
pspad:There is automatic hot key assigning. It's easy to modify it and assign S for search menu.
Hi pspad, I made that change but when I click Alt+S it still doesn't bring up the search menu.
Posted by: pspad | Date: 2016-03-13 10:35 | IP: IP Logged
AxeBlack:Hi pspad, I made that change but when I click Alt+S it still doesn't bring up the search menu.
When it doesn't bring up search menu, does it do anything else?
When you press ALT, you will see underscored letters in the menu. Letters must be unique.
I hope you use left Alt, cause right alt (AltGr) is Ctrl+Alt
There is possible that ALT+S is assigned to any clip or script. Loot into script menu, if there is no shortcut alt+S
Open menu settings / Clip hotkeys if there is no Alt+S shortcut
The fastest way is open TXT file (can be new one) and test it. TXT as default doesn't use code clips.
Edited 2 time(s). Last edit at 2016-03-13 10:38 by pspad.
