You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2455) English
#1 PSPad unicode 4.5.8 (2455) English
Posted by: pspad | Date: 2013-05-09 18:06 | IP: IP Logged
Download links (2.7 MB):
pspad.siliconhill.cz
dl.dropbox.com
Changes to 4.5.8 (2453)
News
New function - Split line - splits line in place of spaces to separate lines
Search/Replace - speed up for case of search/replacement without prompt
Verilog and VHDL user highlighter - added support for PSL (Property Specification Language)
Help for language (Alt+F1) - if selection is available, it's used as content of %word% variable in URL, else word under cursor is used
Code explorer for JS - added support for constructions: myobj.method = function(arg1,arg2)
Search - position of found text is centered horizontally
MSDos batch language - added string support and comment # support
Autohide left gutter
Usage of system icons in File explorer caused big comsumption of GDI resources
PHP code explorer - // in strings break up parsing
UnixShellScript highlighter - wrong highlighter for if=source
Localization of warning for Synchronize project with folder
#2 Re: PSPad unicode 4.5.8 (2455) English
Posted by: mceps | Date: 2013-05-13 00:22 | IP: IP Logged
Hi Jan,
Thanks for the great editor, use it all the time.
I tried to upgrade to latest versions, but they all broke one of the functionality I use all the time: I have "Run Clip" set to Space (instead of shift+space or other combinations, I set it initially, years ago, by editing the file KeyMap.ini directly, it worked and I used it ever since), so I can just type the clip name and press the spacebar and it will auto-complete, but the latest version where this is working is 2441, all the new ones after this cannot set space as the "Run Clip" anymore. Whenever I overwrite 2441 with new versions, I check and "Run Clip" is still set to Space, but it's not working anymore.
Is there a way I can make this work in new version? I'd like to keep one key (spacebar) to expand clips.
Thank you,
Cristian
#3 Re: PSPad unicode 4.5.8 (2455) English
Posted by: pspad | Date: 2013-05-13 06:27 | IP: IP Logged
I didn't make any changes related your problem.
I will try to simulate it.
How did you do the update? Did you let old version and simple replace old files?
Don't install PSpad as portable into Program files folder. No application has rights to write there.
#4 Re: PSPad unicode 4.5.8 (2455) English
Posted by: mceps | Date: 2013-05-13 18:56 | IP: IP Logged
Thanks, Jan, for looking into this issue.
For installing new version, I always just unzip and overwrite files in the existing PSPad folder, which is not installed under Program Files.
Thank you,
Cristian
#5 Re: PSPad unicode 4.5.8 (2455) English
Posted by: poupa | Date: 2013-05-29 08:05 | IP: IP Logged
Hi Cristian,
I have the similiar problem you described (I'm using same update procedure like you). The latest build in which Shift+Space is working to me is build 2447.
BR, Martin
Edited 1 time(s). Last edit at 2013-05-29 08:07 by poupa.
#6 Re: PSPad unicode 4.5.8 (2455) English
Posted by: pspad | Date: 2013-05-29 09:15 | IP: IP Logged
I am still looking for problem reason.
#7 Re: PSPad unicode 4.5.8 (2455) English
Posted by: pspad | Date: 2013-05-29 16:46 | IP: IP Logged
Finnaly, the problem caused nonfunctional Insert clip was found. Next build will be fixed.
