You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2392) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.5 (2392) English
Posted by: holger | Date: 2010-07-07 09:35 | IP: IP Logged
holger:
c3k:
i can (finally) confirm that change detection is working again!!!
grinning smileysmiling smileygrinning smiley
thank you!
Sorry I can't! Closing files by double-click Tab behaves the same as before!
Ohh, there's nothing to fix, but to reset the setting of Close on Double-click in the Properties.... thanks.
It seems that I'm wrong! After a new start of PSPad and closing a File with double-click I get the Problem again.
Please fix, thanks!
#22 Change detection
Posted by: Neil | Date: 2010-07-08 22:59 | IP: IP Logged
Hi Jan,
I use PSPad for editing files used by an "interpeter" type application, i.e. the application reads the file each time file is required.
I have noticed that when this happens, PSPad reports that the file has been changed.
Cheers
Neil
#23 Re: Change detection
Posted by: pspad | Date: 2010-07-09 05:31 | IP: IP Logged
Neil:
Hi Jan,
Cheers
Neil
PSPad should inform you only when another application change open file - it means save it. Reading shouldn have influence
#24 Re: Change detection
Posted by: Neil | Date: 2010-07-13 23:22 | IP: IP Logged
Hi Jan,
Thanks for reply.
I have only noticed this behaviour occuring in this build (it did not behave this way in 2390).
It may be because my program locks the file, and PSPad assumes this a change.
Neil
