You are here: PSPad forum > Developer forum - new builds > Re: Change detection
Posted by: holger | Date: 2010-07-07 09:35 | IP: IP Logged
holger:c3k:i can (finally) confirm that change detection is working again!!!
thank you!Sorry I can't! Closing files by double-click Tab behaves the same as before!
Ohh, there's nothing to fix, but to reset the setting of Close on Double-click in the Properties.... thanks.
It seems that I'm wrong! After a new start of PSPad and closing a File with double-click I get the Problem again.
Please fix, thanks!
Posted by: Neil | Date: 2010-07-08 22:59 | IP: IP Logged
Hi Jan,
I use PSPad for editing files used by an "interpeter" type application, i.e. the application reads the file each time file is required.
I have noticed that when this happens, PSPad reports that the file has been changed.
Cheers
Neil
Posted by: pspad | Date: 2010-07-09 05:31 | IP: IP Logged
Neil:Hi Jan,I use PSPad for editing files used by an "interpeter" type application, i.e. the application reads the file each time file is required.
Cheers
Neil
PSPad should inform you only when another application change open file - it means save it. Reading shouldn have influence
Posted by: Neil | Date: 2010-07-13 23:22 | IP: IP Logged
Hi Jan,
Thanks for reply.
I have only noticed this behaviour occuring in this build (it did not behave this way in 2390).
It may be because my program locks the file, and PSPad assumes this a change.
Neil
