You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2296) English
Posted by: pspad | Date: 2007-11-25 13:21 | IP: IP Logged
mahira:The new behaviour is no different from working directly on a remote file.There are many many times when I (and possible many others) NOT prefer to save a local version to the FTP server.
I was more than happy with the previous behaviour of the "Save to FTP" command. I was able to continue saving just locally.
Now, after a "Save to FTP" command it will save ANY FURTHER EDITING of the file both locally and remotely.
isn't there anyone agreed with me
Regards,
Mahir
OK. What about such behavior:
1. If file was open from FTP and Save to FTP was used, PSPad will change file properties to new FTP location
2. If file is local and SaveToFTP is used, PSPad saves it to FTP only and file will stay as locall file.
Is it intuitive enough for you?
Posted by: mahira | Date: 2007-11-26 10:21 | IP: IP Logged
Hi Jan,
this is great
I think that this is the case with the last build (2297) ?
At the second one (2. if file is local...) the file is also saved to its current local directory (which is much better of course)
Thank you,
Mahir
pspad:OK. What about such behavior:1. If file was open from FTP and Save to FTP was used, PSPad will change file properties to new FTP location
Posted by: pspad | Date: 2007-11-26 11:15 | IP: IP Logged
Yes, it is in 2297 already
To he point 2)
If you edit local file and call Save to FTP, PSPad saves it to current FTP folder only. Nothing else.
