You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2291) English
Posted by: RB_Devils | Date: 2007-11-13 17:21 | IP: IP Logged
pspad:Background depends of the highlighter background. If you set different background for your JScript, youwill get it in multihighlighter too.
Show this case:
<script language=javascript>
var activeDocument = "<%= activeDocument %>";
</script>
You correctly color the background Of JavaScript but don't color with different color the background of this piece of code:
"<%= activeDocument %>" with the background color of MS VBScript!
Posted by: pspad | Date: 2007-11-13 17:30 | IP: IP Logged
Ok. Again.
HTML multihighlighter isn't multilevel.
It will highlights your JavaScript inside HTML, but you want highlight VBScript inside JavaScript inside HTML.
Posted by: wal | Date: 2007-11-14 06:51 | IP: IP Logged
pspad:fubo:Hi all,Code explorer for C is broken from last beta release. Basically a line like "if( ... )" is treated as a function because it ends without ";", so it's reported in Function pane.
Sorry, I can't simulate it. Send me some example what causes this problem.
I am not sure if this is the same problem, but C/C++ code explorer shows line if (b == 0) as function in following example:
void test1( void)
#ifdef X
// some code...
#else
if (a == 0) {
// some code...
#ifdef Y
// some code...
#endif
#endif
if (b == 0)
a = 0;
Posted by: fubo | Date: 2007-11-14 08:58 | IP: IP Logged
wal:I am not sure if this is the same problem, but C/C++ code explorer shows line if (b == 0) as function in following example:void test1( void)
#ifdef X
// some code...
#else
if (a == 0) {
// some code...
#ifdef Y
// some code...
#endif
#endifif (b == 0)
a = 0;
Yes it's the same problem.
Other issues on code explorer:
- if the procedure is declared extern it's not shown in the code explorer;
- procedure pointers used as parameters in a procedure definition is shown but should not if the parameter is on a new line.
Example, if:
extern int proc( const int par1,
void (*par2)(void),
const int par3)
code explorer shows only:
void (*par2)(void)
If:
extern int proc( const int par1, void (*par2)(void), const int par3)
code explorer shows nothing.
Posted by: yn | Date: 2007-11-14 11:19 | IP: IP Logged
pspad:In this case use External Application, not compiler
Well, my reason not to use ExternalApp are :
1. I'd like to avoid creating temporary files. I'd like to directly save changes to the real file.
2. If there is selected text, it would be saved as a temp file and passed to the ExternalApp, instead of the full file (I've used "%File%" though), and I couldn't find any setting related to this. Is it not exposed ?
