You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2284) English
Posted by: gurbao | Date: 2007-10-29 14:54 | IP: IP Logged
Hi again,
also when I try to capture Powershell output in memo logwindow, I just see "garbage".
I believe powershell output is Unicode?
At least the two first bytes is hex(FFFE)...
I would appreciate if anyone could confirm this...
Thanks,
Posted by: msweeney | Date: 2007-10-29 17:34 | IP: IP Logged
I'm having the same log issue with the SQL highlighter only using in list mode.
When did the assignLog() function get deprecated? This is the first beta I installed in a long while, so I didn't notice this before (my scripts broke).
Is there a way to specify memo mode through scripting?
Posted by: Fred38 | Date: 2007-10-30 07:45 | IP: IP Logged
hi Jan,
Thanks for this realease.
Do you know when the next 'stable' version will be done, last is october 2006.
rgds
Frederic
French user of Pspad in Isere
Posted by: pspad | Date: 2007-10-30 12:08 | IP: IP Logged
I am waiting for the current English help
Posted by: naputtelija | Date: 2007-10-30 14:41 | IP: IP Logged
When releasing new version, feel free to include my PowerShell syntax and clip files (http://www.pspad.com/files/pspad/rozsireni/134-Windows%20PowerShell.zip).
Posted by: francheu | Date: 2007-10-31 06:55 | IP: IP Logged
naputtelija:When releasing new version, feel free to include my PowerShell syntax and clip files (http://www.pspad.com/files/pspad/rozsireni/134-Windows%20PowerShell.zip).
I think you could even include all the syntax and clips files that users have put on the PSPad website...
I don't know if it is a good idea to also include the scripts, as all of them are not necessarily useful for all users. Maybe you could put it as an option in the installer.
Posted by: pitti | Date: 2007-11-01 22:07 | IP: IP Logged
naputtelija:I don't know if this is new problem or not, but I just noticed this: Make a new txt file, write character '<' or '|' on the first line and you cannot save file. File dialog does not show up.
Same problem for me. I think it's a new problem. (since this build)
Posted by: pspad | Date: 2007-11-02 05:59 | IP: IP Logged
I corrected this problem yesterday night.
Posted by: pitti | Date: 2007-11-02 07:14 | IP: IP Logged
pspad:I corrected this problem yesterday night.
A big thanks.
Posted by: mahira | Date: 2007-11-03 07:35 | IP: IP Logged
is the correction included in the currently available 2284, or will you release a new build ?
Regards,
Mahir
